Author Topic: injectors  (Read 14940 times)
Reply #45December 23, 2009, 02:42:21 pm
phantom59
  • 61
Re: injectors
« Reply #45 on: December 23, 2009, 02:42:21 pm »
Ok I tried the tester both ways and got the same readings.
#1-400psi
#2-450psi
#3-400psi
#4-400psi
This doesn't sound good to me. After I did 4 & 3 I thought ok Chinese gauge but then I did 2 and got a much higher reading and figured that there is a problem. Most likely stuck rings or the cylinder walls rusted from sitting so long and they are scored.
Hope someone here can tell me something I don't know PLEASE.
With this head design there is no way to scope the cylinders and see what they look like.
Reply #46December 23, 2009, 02:56:46 pm
Re: injectors
« Reply #46 on: December 23, 2009, 02:56:46 pm »
I've seen much lower. You'll be fine. Have you checked your valve lash lately?
Reply #47December 23, 2009, 03:12:19 pm
phantom59
  • 61
Re: injectors
« Reply #47 on: December 23, 2009, 03:12:19 pm »
I have only checked what we have discused here. You think 400 is ok it is barley above minium in the manual.
Reply #48December 23, 2009, 04:51:31 pm
phantom59
  • 61
Re: injectors
« Reply #48 on: December 23, 2009, 04:51:31 pm »
I am going to oil it and try one more time then put it back together. Wife picked up the new heat shields local NAPA store had 4 in stock. I told him to hide them for me and I would be there.
Next I will go for the IP timing. Should I pull the cover and confirm belt timing first?
Reply #49December 23, 2009, 05:19:25 pm
Re: injectors
« Reply #49 on: December 23, 2009, 05:19:25 pm »
Your compression results are great.
Agreed...compression is not your issue.  ;)
Reply #50December 23, 2009, 06:58:28 pm
phantom59
  • 61
Re: injectors
« Reply #50 on: December 23, 2009, 06:58:28 pm »
Ok it lives again and no leaks ;D
Now on to the pump  ::)
I will try to post some pictures of the car.
