General Information
General
Pump Triangle Socket
Topic: Pump Triangle Socket (Read 5672 times)
December 16, 2009, 11:01:15 pm
ffgb
December 16, 2009, 11:01:15 pm »
I am looking for the special pump triangle socket so I can disassemble my IP. I have found one at on the MetalNerd website and the KermiTDI website for about $24. Will this one work with my stock VE 84 Rabbit IP? I just didn't know if there were different size triangle bolts because the MetalNerd tool is used on a TDI pump, not a NA pump?
Thank You
December 17, 2009, 01:49:50 am
Re: Pump Triangle Socket
December 17, 2009, 01:49:50 am »
I ground 3 flats off a 1/2" 6pt, and it worked great.
I tried a super cheap one(you know the 40 tools for 5 bucks set) first, and it was not up to it.
December 17, 2009, 05:13:58 am
anto
December 17, 2009, 05:13:58 am »
I took mine off with a chisel and hammer
Then a 13mm socket hammered onto it to take it out fuul way...
December 17, 2009, 09:06:18 am
December 17, 2009, 09:06:18 am »
What triangle bolt? There are 2 on the old pumps, and 2 on the TDI pumps but only 1 of them is the same. I highly doubt that the metalnerd one is the correct one.
December 17, 2009, 09:17:02 am
December 17, 2009, 09:17:02 am »
Don't forget your safety glasses
General Information
General
