no start...
Topic: no start... (Read 2181 times)
December 16, 2009, 07:16:09 am
goon
User+
no start...
December 16, 2009, 07:16:09 am »
1982 caddy 1.6 n/a
i was driving fine havent had any problems with it at all, i parked it at my friends house and it was running fine when i turned it off... i went to start it and all i got was crank crank crank.... i checked the timing belt still on and tight.. then checked fuel.. theres no fuel in the line going from the filter to the IP and theres no fuel in the hard lines either, i tried loosening the injector fitting and cranking to get fuel to the injector but its not even pulling fuel to the pump.
what the hell is wrong did the pump just fail???
im new to diesel here so any ideas would be appreciated
also new things ive found out, if i pull the banjo fitting off the fuel filter and put it in a can of diesel it will pull fuel into the ip, but still wont push through to the injectors..
also there is a nice mess of fuel under the ip didnt notice it before but theres alot of fuel there...
are the seals gone on the pump and why would it just not start after parking it...
my baby..
December 16, 2009, 10:49:15 am
rabbitman
Re: no start...
December 16, 2009, 10:49:15 am »
Check that the stop solenoid on the pump clicks when you turn the key to run, if it's not working fuel will circulate through the pump but won't go to the injectors.
If it won't click (make sure it's getting 12V) then take it out and remove the little spring and plunger and put the body back in, you'll have to stall it to shut down.
December 16, 2009, 02:23:15 pm
goon
User+
Re: no start...
December 16, 2009, 02:23:15 pm »
i checked to see if the solenoid was getting 12v and it is when the key is on. how do i tell if its working properly?
December 16, 2009, 02:24:33 pm
dash cunning
User+
Re: no start...
December 16, 2009, 02:24:33 pm »
u should hear it click when u touch 12v to it.
79' rabbit 1.5 n/a, 89 golf gasser, 91 jetta gasser, 72 westy.
December 17, 2009, 08:28:17 pm
goon
User+
Re: no start...
December 17, 2009, 08:28:17 pm »
alright... checked that and it wasn't clicking so i took the plunger and spring out and put it back in, now my question is to prime the air out of the hardlines that go to the injectors.. how long do i have to crank it for? i loosened the hardline going to one of the injectors and cranked for a about 40-50 seconds and still no fuel... (by the way i am working with a very dead battery and also about 10F degree weather)....( took the line off the fuel filter and put it in a can of diesel to make sure i could get it started first before i deal with maybe other issues like priming the rest of the system)
December 17, 2009, 09:02:58 pm
Re: no start...
December 17, 2009, 09:02:58 pm »
Pull start it. Just a little while and it will pull fuel up in it.
Did you get a new seliniod? Or was it the line going to the seliniod?
Round 2
December 19, 2009, 09:00:38 pm
goon
User+
Re: no start...
December 19, 2009, 09:00:38 pm »
thanks for all the help guys i found out that the fuel cut off solenoid went bad and all my messing around with the fuel lines emptied the pump so i took the plunger out of the solenoid and then took the fuel return bolt off and filled the pump up with fuel, cranked it over and it spit and sputtered itself to life!
thanks again guys
no start...
