Author Topic: Sizing TDI for Explorer swap  (Read 3845 times)
December 10, 2009, 09:06:54 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
« on: December 10, 2009, 09:06:54 pm »
Hi guys,
I'm starting the research for a 1994 Ford Explorer->TDI conversion and was wondering if anyone's seen a swap of this nature before? I'm going to go V8 with it first, but ultimately, want to put a diesel engine into it. Since I'm in Canada, the engines that seemed most available were actually Mercedes diesel or an engine from a Sprinter. I imagine the perfect fit would be a V6 TDI from Europe, but I'm curious what the import cost would be on something like that and what varieties I might be able to get.
Anyhoo. This won't be happening until at least next summer, but I figured I'd throw out a line and get some gray matter churning a bit.
Reply #1December 11, 2009, 02:20:23 pm
boxer246
  • 109
Re: Sizing TDI for Explorer swap
« Reply #1 on: December 11, 2009, 02:20:23 pm »
Haven't seen any TDI's put into Fords.....there are adaptor plates available to mate a VW block to a Toyota tranny....the ones that were mated to the 22R motors.  So there is people putting them in Toyota trucks now.  I assume you could do the same with a 4-Runner if you wanted a SUV.  That might be the next best thing to your Explorer.  There are also adapter plates available to bolt a Mercedes 5 cyl diesel to Chevy auto trans.  The possibilities for this combination into various vehicles would be almost endless.  I love these VW diesels, but maybe a Merc 5 cyl would be a better match for the Explorer.  Just my 2cents.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #2December 11, 2009, 04:31:54 pm
410
  • 581
« Reply #2 on: December 11, 2009, 04:31:54 pm »
There's a guy who calls himself Lone Ranger over at tdiclub that did a 1.9 tdi alh in a Ranger which would be pretty much the same as the explorer.  There's a sticky in the conversion section on all the different conversions and I found his build under "other".
