Author Topic: Lab results for popular fuel additives  (Read 7722 times)
December 09, 2009, 02:31:54 pm
fc steve
  • 30
« on: December 09, 2009, 02:31:54 pm »
This may be a super repost but its good info! The samples where professionally tested in a lab. Sticky material?
http://www.dieselplace.com/forum/showthread.php?t=177728
Reply #1December 09, 2009, 10:22:14 pm
Re: Lab results for popular fuel additives
« Reply #1 on: December 09, 2009, 10:22:14 pm »
Very good.
Sticky material?
I think so since the question comes up once in a while. 'course, the search works too ;)
« Last Edit: December 09, 2009, 10:23:46 pm by rabbitman »
Reply #2December 10, 2009, 01:20:58 pm
blackdogvan
  • 574
« Reply #2 on: December 10, 2009, 01:20:58 pm »
Nice to see the Power Service stuff i've been using fell in the completely useless section... >:(
Looks like the FPPF stuff is the way to go since its #2 & half the cost of #1.
On a lighter note if you scroll 1/2 way down that page you will see the BEST AVATAR IMAGE EVER for user Duratys!!
1991 Vanagon 1.9 mTDI
Reply #3December 10, 2009, 05:49:17 pm
fc steve
  • 30
« Reply #3 on: December 10, 2009, 05:49:17 pm »
Yeah i have been using power service too hahaha! Ill keep using it for the cetane boost tho. There is a b100 station in town ill just dump a quart in every tank.
2% biodiesel pretty much everything else. And for like 60 cents a tank!
Reply #4December 10, 2009, 07:56:29 pm
macka
  • 957
« Reply #4 on: December 10, 2009, 07:56:29 pm »
hmmm didn't see ATF up there
Quote from: Vincent Walden
Reply #5December 10, 2009, 10:36:09 pm
fc steve
  • 30
« Reply #5 on: December 10, 2009, 10:36:09 pm »
The way it was all done is people put money into the pool to get certain products tested. I would assume that motor oil would work at least as good as the atf as engine oil is a lubricant with some detergents vs atf that has detergents and friction modifiers. Which basicly means better friction for the bands clutches and plates. Which is the opposite of what you want in your injector pump.
