General Information
Troubleshooting
86 vw 1.6 na clunking when starting out, cluthin in-out, decelerating
Topic: 86 vw 1.6 na clunking when starting out, cluthin in-out, decelerating (Read 4823 times)
December 08, 2009, 09:34:53 pm
jetAdub
Newbie
December 08, 2009, 09:34:53 pm »
Hi everyone, new to the site, and I have a problem with my car...(like you've never heard that before)
This morning leaving for work, i noticed a clunk that got worse. Seems like when i let off the clutch it happens. Noticed that when i decelerate it also clunks, not so much when accelerating. Also it seems to be coming from the front drivers side, which makes me think its a CV joint; although it doesn't clunk around turns and you can't feel it in the steering wheel, or something driveline related. I have a feeling it may have something to do with the clutch... any thoughts anyone? did some browsing sounds like some people have had this problem before.
Thanks,
Any input is much appreciated... thanks
December 08, 2009, 09:46:04 pm
Re: 86 vw 1.6 na clunking when starting out, cluthin in-out, decelerating
December 08, 2009, 09:46:04 pm »
is your cv boots busted? indicating it may be cv joints?
my passenger cv joint clunks around turns, and only clunks while driving at certain angles of the wheel being turned.. its weird
December 08, 2009, 11:20:16 pm
rabbitman
December 08, 2009, 11:20:16 pm »
If it clucks real bad letting the clutch out in reverse then I'd say the rear engine mount failed and the clunk is the tranny coming up and hitting the body
Grab the drivers side end of the tranny and pick up hard, if it comes up that's for sure the problem.
My Dad's golf did it for years until we finally found it.
December 09, 2009, 02:11:18 pm
jetAdub
Newbie
December 09, 2009, 02:11:18 pm »
Yeah, another guy at work here said it might be the rear mount. I replaced the front mount not to long ago. The thing is, i don't think it is CV joint cause i would feel it in turns, and i don't hear or feel anything in turns. I will take a look at the mount tonight and report my findings. thanks
December 10, 2009, 11:50:05 am
jetAdub
Newbie
December 10, 2009, 11:50:05 am »
The mount is solid. Must be the cv shaft or the clutch maybe? can't feel it in the steering wheel. I was thinking it may be a driveline bearing? any thoughts
December 11, 2009, 01:32:43 pm
clbanman
Cambridge, Ontario
December 11, 2009, 01:32:43 pm »
It sounds like it's happening when you change the loading on the wheels. Check to make sure all bolts are torqued properly. Guess how I know?
Calvin
91 VW Golf 1.6NA 5spd
December 12, 2009, 09:23:45 am
jetAdub
Newbie
December 12, 2009, 09:23:45 am »
Yeah, i will have a look tomorrow. It does happen when the load on the wheels changes. When you step on the gas it doesn't do it, but slow down, or let your foot off the gas, or even push the clutch in, and it does it. Will follow up tomorrow... thanks
December 12, 2009, 05:36:25 pm
smoken u
December 12, 2009, 05:36:25 pm »
my car had the same problem last year, really bad clunk when clutching or decelerating, mine ended up being the lower control arm bushing on the drivers side, you may want to give yours a check, justjack the car up and use a pry bar to move th control arm back and forth, and if it looks like its got alot of play, its probably shot
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works
You don't rev a VW diesel, you increase the clatter.
December 28, 2009, 12:47:14 pm
jetAdub
Newbie
December 28, 2009, 12:47:14 pm »
Yeah fixed it! it was the drivers side inner cv joint, i just replaced the whole axle. The cage that hold the balls in place on the joint was cracked through and there where definite signs of metal in there, so we replaced it, and also found that the passsenger side lug bolt was loose which also contributed to the clunking we heard. All is fixed, and it really wasn't that bad to change either. thanks for the help guys
General Information
Troubleshooting
