Author Topic: Air water IC pump circuit  (Read 6152 times)
December 05, 2009, 02:43:18 pm
blackdogvan
  • 574
« on: December 05, 2009, 02:43:18 pm »
How would you wire a electric water pump for a air/water IC? I was thinking a relay triggered from the load reduction circuit, anyone think of a better option?
1991 Vanagon 1.9 mTDI
Reply #1December 05, 2009, 03:05:20 pm
mystery3
  • 774
Re: Air water IC pump circuit
« Reply #1 on: December 05, 2009, 03:05:20 pm »
How are the after run pumps on the audi 5000 turbo wired in/switched?
Reply #2December 06, 2009, 07:55:11 am
blackdogvan
  • 574
« Reply #2 on: December 06, 2009, 07:55:11 am »
Thermo switch & a relay i think. hmmm thats not a bad thought!
Reply #3December 06, 2009, 08:20:35 am
mystery3
  • 774
« Reply #3 on: December 06, 2009, 08:20:35 am »
I'm not sure if the pumps up to the task of running all the time or how much flow they create.  I just thought the wiring setup might be useful perhaps with a lower temp switch so it'd run when the cars warmed up? The little bracket that holds the pump on the 5k is pretty cool too.
Reply #4December 06, 2009, 09:50:15 am
« Reply #4 on: December 06, 2009, 09:50:15 am »
VR6 passats (I think) use an auxiliary electric coolant pump that may work. I'm not sure how much they flow though.
Reply #5December 06, 2009, 10:04:21 am
blackdogvan
  • 574
« Reply #5 on: December 06, 2009, 10:04:21 am »
That's the exact pump i have for this. Its very similar to the Audi turbo aux coolant pumps.
Reply #6December 07, 2009, 11:03:20 am
« Reply #6 on: December 07, 2009, 11:03:20 am »
I have one in the heater circuit of my bunny, with it on I can tell very little difference. Before I installed it I put the inlet in a bucket and it really sprayed water out ;D
