Author Topic: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP  (Read 40745 times)
Reply #30December 17, 2009, 07:43:50 am
Re: VANAGON/T3 SILICONE COOLANT HOSES *GROUP BUY* SIGN UP
« Reply #30 on: December 17, 2009, 07:43:50 am »
Not to threadjack, but is there a set already made for VR6 engines?  I know there is a Samco VR6 set, but it's very expensive.
Thanks,
Reply #31December 17, 2009, 08:46:22 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #31 on: December 17, 2009, 08:46:22 pm »
I'll take 3 sets of euro DV hoses.
Reply #32December 18, 2009, 08:12:44 am
GEE-BEE
  • 1604
« Reply #32 on: December 18, 2009, 08:12:44 am »
SAMCO IS ALREADY 40 % MORE FOR THE EXCHANGE RATE: % POUND TO DOLLAR...
Euro model VR6 are different
Gee-Bee
Jetta MKIII and AAZ engine are next..
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #33December 18, 2009, 08:38:41 am
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #33 on: December 18, 2009, 08:38:41 am »
I'm a bit confused?  Are you making a whole bunch of different hoses, or a universal-type hose?  Have you sent any of the original '82 or '83 style diesel hoses to be tooled?  (The TIICO hoses are actually gasser ones)  I guess I'm wondering if you're making any with the narrower ends that would work for the stock '82 setup?  Do you need some '82 or '83 hoses? - I can ask around..
1981 1.6 NA Pickup
1982 1.6 NA Westfalia
1990 1.6 NA Jetta (not running)
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #34December 18, 2009, 10:36:29 am
GEE-BEE
  • 1604
« Reply #34 on: December 18, 2009, 10:36:29 am »
Right now I have a set of Tiico hoses going to tooling, I have a set of MKIII and engine AAZ coming
So a complete set would be correct
GB
[email protected]
Giles Pump OHC
MK1 JETTA DASH
Reply #35December 18, 2009, 07:28:39 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #35 on: December 18, 2009, 07:28:39 pm »
By a "whole bunch of hoses" I meant multiple sets (one that would fit the stock diesel?) or just the AAZ/TIICO hoses which fit the gas to diesel conversions?  By universal I meant a set that would fit both the later AAZ/etc gas>diesel conversions and the stock setup (stepped ends for the smaller pipes?)
If you're interested in supplying a set that fits the stock engine, I'm sure I/we could get some together.. I may have a set available to loan out after the holidays (possibly a "new" rig).
Thanks,
Will.
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #36December 18, 2009, 11:20:37 pm
GEE-BEE
  • 1604
« Reply #36 on: December 18, 2009, 11:20:37 pm »
TICCO ASSY'S ARE 375.00 PER SET, advise color
We need a firm order of 25 set's so there is no 2600.00 tooling charge.
This for the TIICO Motor , see them at Vancafe.com
Giles Pump OHC
MK1 JETTA DASH
Reply #37December 27, 2009, 11:09:40 am
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #37 on: December 27, 2009, 11:09:40 am »
BusDepot has a nice diagram and parts list showing which hoses are NLA for the 82-83 diesel Vanagons.
That little bypass hose #8 is less than $6, but the octopus hose #6 and the expansion tank/heater return to water pump hose #9 are NLA, while the radiator/oil cooler (068121073C '83-'84 - gotta check the '82) to pump hose is still available, it's pricey at $120.
http://busdepot.com/details/waterdiesel.jsp
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #38January 28, 2010, 03:31:31 am
Syncroincity
  • 727
« Reply #38 on: January 28, 2010, 03:31:31 am »
Aaallll righty then...
Are we ready to start the ordering process? We need 25 paid-up orders to get the good no-tool prices. I had a lot of interest on The Samba as well, shouldn't be an issue.
Is everyone recovered from the holidays enough to start this back up? :D
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #39January 29, 2010, 06:32:12 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #39 on: January 29, 2010, 06:32:12 pm »
Im ready.
Reply #40January 29, 2010, 09:58:50 pm
williamtaygan
  • 33
    • Arctic Vegwerks
« Reply #40 on: January 29, 2010, 09:58:50 pm »
Can you clarify if these are TIICO inline gasser hoses or JX turbo diesel hoses (bypass is different - anything else?)  Also, are these tooled/adapted for the '82/'83 stock diesels?
1981 1.6 NA Pickup
1991 1.6 eco Jetta
1994 1.6 TD Jetta
Reply #41February 01, 2010, 02:00:56 pm
MichaelBuck
  • 24
« Reply #41 on: February 01, 2010, 02:00:56 pm »
I'd like a set for a TDI conversion.  Black?
Reply #42February 03, 2010, 05:21:21 am
CdnVWJunkie
  • 309
« Reply #42 on: February 03, 2010, 05:21:21 am »
I'd like clarification as well please.
Reply #43February 03, 2010, 08:41:01 am
GEE-BEE
  • 1604
« Reply #43 on: February 03, 2010, 08:41:01 am »
Ask Syncro
he has pricing
« Last Edit: February 04, 2010, 08:54:40 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #44February 03, 2010, 08:14:06 pm
Syncroincity
  • 727
« Reply #44 on: February 03, 2010, 08:14:06 pm »
The set I sent to you is from a JX turbodiesel Vanagon.
JC McCavitt
'98 Jetta Wolfie
