For Sale/Looking For
Parts for Sale/Wanted
FS: 92 Jetta TD 4 door
Topic: FS: 92 Jetta TD 4 door (Read 6327 times)
December 04, 2009, 06:40:09 am
zozep
December 04, 2009, 06:40:09 am »
Aright, here it is. 2000 as is. I can part it out and get at least that if not more, but it's been properly built, and I dont have the time to do that. I have all the documentation of the work done to it by pro. mechanic if you care to see it.
If i don't get what I'm asking, I'll just leave it in the garage and rip around in it in the summer. I'm negotiable to a point, but lowballs get ignored.
1992 Jetta 4 door black.
-Comes with a 2nd 1992 Jetta, sky blue 330k kms, used as a parts car, its the full car minus a few small things like one tail light.
-Head was glass beaded and is still shinny (1 year)
-Metal head gasket from 1.9 (1 year)
-all new valve cover seals (1 year)
-Glows (1year)
-injectors (1 year)
-Giles Pump, set to 25 PSI (1 year)
-Intercooler and piping (3 months)
-Downpipe from 1.9 Mk3 to 2.5 inch straight pipe (1 year)
-Alt rebuilt (1 year)
-Spiral Cell batt. (1 year)
-2 gauge A Pillar pod with backlit gauges, EGT and Boost (1 year)
-Starter, reman from bosch (1 year)
-Short Shift kit
-Dual Round grille with FK Crystals and Hi/Low HIDs from VVME (1 year)
-JVC Mp3 deck with infinity fronts and rears with amp kit, sub avail for more. (1 year)
-Water Pump, Timing Belt, tensioner all has less than 30k on it (1 year)
-new rad from Jegs from a GTI with Jegs highpull fan (3 months)
-Cross drilled front roters
-FK Hi-Tec Suspension kit with upper strut mounts (1 year)
-BBS RA's with Miranda Rubber (1 season), 4 Michelin Arctic Alpines on Winter Rims
There's probobly more, and i'll add it as people inquire.
I'll post pics soon, although i'm sure if I look through my posts, I'll be able to find a few.
Last Edit: December 14, 2009, 07:03:02 am by zozep
SOLD: 92 Jetta TD, Giles Pump set to 30 psi, MLS Head Gasket, ARP head studs, Huge eBay intercooler, blocked WG, FK suspension, 1.9L AAZ downpipe to 2.5 inch straight back.
Current: 2000 TDi, 01M
DG Full skid plate, Cat 2 micron Fuel Filter, Scanguage II, 4700kHIDs, DG RacePipe
December 04, 2009, 07:00:54 am
zozep
Re: FS: 92 Jetta TD 4 door
December 04, 2009, 07:00:54 am »
December 09, 2009, 08:10:39 am
zozep
December 09, 2009, 08:10:39 am »
Bump
Price drop 2000 as is. and i'll even throw in my parts car and any other diesel parts I have lying around... I do have an N/A fuel pump that is in great condition that will go with it.
December 09, 2009, 08:11:43 am
zozep
December 09, 2009, 08:11:43 am »
Need this gone so come get it...
December 09, 2009, 12:09:23 pm
Patrick
December 09, 2009, 12:09:23 pm »
Might help if you tell people where you are..................
December 09, 2009, 12:50:49 pm
zozep
December 09, 2009, 12:50:49 pm »
Quote from: Patrick on December 09, 2009, 12:09:23 pm
Good call.
Thanks.
Body= 6/10
Interior 7/10
Mechanical 8.5/10
Lots of car here, a good project and you get 2 cars for 2000
December 10, 2009, 04:17:46 am
zozep
December 10, 2009, 04:17:46 am »
morning bump
December 11, 2009, 04:02:56 am
zozep
December 11, 2009, 04:02:56 am »
bump
December 14, 2009, 07:01:53 am
zozep
December 14, 2009, 07:01:53 am »
bump, updated.
December 15, 2009, 04:05:46 am
zozep
December 15, 2009, 04:05:46 am »
December 18, 2009, 07:18:08 am
zozep
December 18, 2009, 07:18:08 am »
in response to question from "SR Heer":
Intercooler was a kit I ordered from eBay, it came with the piping, couplers and clamps. I did however have to find couplers to go from 1.5 inch inlet on the turbo to the 2.5 inch sized pipe for the intercooler..which was a pain.
Rad comes from a an 89 GTI and the rad fan is from Jeg's, thier high pull 8 blade 10 inch I believe, great fan, very quiet and pulls way more CFM than the stock fan and is much smaller.
2000 for this and the parts car is a steal.
Reply #11
December 21, 2009, 10:52:10 am
zozep
Reply #11 on:
December 21, 2009, 10:52:10 am »
Reply #12
January 06, 2010, 02:06:32 pm
zozep
Reply #12 on:
January 06, 2010, 02:06:32 pm »
still here
Reply #13
January 07, 2010, 05:01:17 am
zozep
Reply #13 on:
January 07, 2010, 05:01:17 am »
Reply #14
January 07, 2010, 08:37:31 am
GEE-BEE
Reply #14 on:
January 07, 2010, 08:37:31 am »
free bump for a great price
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
