TDI Engine -General Info
11mm Vs 10mm pump T belt change interval
Topic: 11mm Vs 10mm pump T belt change interval (Read 2868 times)
December 03, 2009, 04:30:27 pm
blackdogvan
December 03, 2009, 04:30:27 pm »
Is there a difference in the VW recommended t belt change interval for 11mm & 10mm pumps (auto Vs manual tranny).
1991 Vanagon 1.9 mTDI
December 03, 2009, 07:31:48 pm
diesel smoke
Re: 11mm Vs 10mm pump T belt change interval
December 03, 2009, 07:31:48 pm »
The automatics had a shorter interval than the manual ones, but once you get the 100K belt kit, you don't got to worry. It's still 100K.
'99.5 Bora TD
I
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
