Author Topic: injector sealing problems  (Read 3982 times)
November 29, 2009, 10:37:36 am
85gti
« on: November 29, 2009, 10:37:36 am »
i can't get the damn brass o-ring out of the head and it is pissing diesel all over the place... ???
any suggestions will be tried, i don't want to screw anything up though  :P
thanks in advance.
Reply #1November 30, 2009, 11:32:33 am
gigaz2
  • 626
Re: injector sealing problems
« Reply #1 on: November 30, 2009, 11:32:33 am »
brass? its supposed to be copper, and when it fails what you get is compression from the cylinders escaping.
not a good sound  ;D
if its liquid diesel your getting, its from the injector bodies, high pressure lines or usually from the return lines.
don't get your naked fingers anywhere near a diesel leak, if you get a tiny spec into your skin its byebye finger, or hand depending how far to the nearest hospital :o
Reply #2November 30, 2009, 04:08:26 pm
85gti
« Reply #2 on: November 30, 2009, 04:08:26 pm »
not a good sound  ;D
Really?  Good to know.  It is copper I guess and I know the sound of the compression escaping and it is not that.  I am just getting liquid from the body I guess.  Is there anyway to fix this without using a new injector?  I have tried two so far and they both leaked...  basically is there anything else I can do before I go and buy a new injector?  I guess having two copper o-rings is not as bad as I first thought  ;D
Reply #3December 01, 2009, 05:47:13 am
gigaz2
  • 626
« Reply #3 on: December 01, 2009, 05:47:13 am »
you can repair those injectors, any diesel shop can do that
using two washers or one with a different shape is a no no, more smoke, less power, bad fuel economy
Reply #4December 03, 2009, 06:10:55 pm
oldskool rich
  • 446
« Reply #4 on: December 03, 2009, 06:10:55 pm »
ive had diesel on my finger and in my mouth and all over my face (dont ask)
i didnt go to hospital and nothing bad happend
i feel great
f6squared I.D.S.T
Reply #5December 04, 2009, 11:32:06 am
gigaz2
  • 626
« Reply #5 on: December 04, 2009, 11:32:06 am »
i feel great
ROFTL
problem is when it gets injected INTO the skin (but you know that)
Reply #6January 24, 2010, 09:48:24 pm
sprstu
  • 99
« Reply #6 on: January 24, 2010, 09:48:24 pm »
I had the same thought... Ive drank diesel by accident and havnt died yet. But yes, if you take a high pressure blast and it gets INJECTED into you, then youre in a world of pain.
Mk1 caddy TD, mk4 Golf Tdi
