Who's running poly mount inserts?
Topic: Who's running poly mount inserts? (Read 4083 times)
November 25, 2009, 08:07:56 pm
ToddA1
November 25, 2009, 08:07:56 pm »
I'll be replacing the broken p/s engine mount on my 82 Rabbit. AutohausAz didn't stock the HDs, just the standard Meyle mount.
Some have said to fill them with epoxy to make them last longer and I've heard a few people say to put a poly insert in. Who's done any of the above and what are your opinions? As much of a pain as it's going to be to swap the mount, I only want to do it once.
-Todd
November 25, 2009, 08:39:19 pm
Re: Who's running poly mount inserts?
November 25, 2009, 08:39:19 pm »
I think i read somewhere that poly mounts on the side will shake your car to smithereens... because those two hold most of the weight of the engine i assume?... or it was the other way...
at any rate near solid mounts on a diesel are probably something you want to steer clear of.
November 25, 2009, 09:59:38 pm
maxfax
November 25, 2009, 09:59:38 pm »
Poly mounts are MISERABLE on the left and right side mounts.. The best combo I've found is stock mounts in those two, and poly on the front and rear mount.. It isn;t unbearably rattly, yet because the front and rear mounts are firmer the engine doesn;t rock around in there as much and keeps the left and right mounts lasting longer...
November 26, 2009, 09:01:45 am
ToddA1
November 26, 2009, 09:01:45 am »
I've always heard the same about the side mounts, but was a bit curious when I've heard others state otherwise.
I've always run the front poly, but have heard the rear poly block will just break into chunks and disintegrate.
-Todd
November 26, 2009, 03:20:07 pm
maxfax
November 26, 2009, 03:20:07 pm »
Polys would probably be fine on a gasser.. Maybe on a MK2 and up...
I have the poly rear mount, and so far so good, but I'm only running an N/A too..
November 26, 2009, 04:06:06 pm
ToddA1
November 26, 2009, 04:06:06 pm »
Approximately how long, and what mileage is on the rear?
-Todd
November 26, 2009, 06:09:27 pm
FineFrank
November 26, 2009, 06:09:27 pm »
Buy a heavy duty mount from Techtonics. I have 60k on mine and it's still fine.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
November 26, 2009, 08:59:38 pm
maxfax
November 26, 2009, 08:59:38 pm »
Quote from: ToddA1 on November 26, 2009, 04:06:06 pm
-Todd
Probably about 60K miles.. I put it in there about a year and a half ago...
November 26, 2009, 09:44:14 pm
mystery3
November 26, 2009, 09:44:14 pm »
I have the prothane passenger and driver side mounts and the heavy-duty front and rear. It has a good amount of vibration at idle, with the rpms up a bit it's not bad. I had all four and it was a little bit too much.
What other vehicle have you driven with poly/delrin/solid motor and/or transmission mounts?
November 27, 2009, 11:09:07 am
ToddA1
November 27, 2009, 11:09:07 am »
Only gas Rabbits. The fronts and rears were poly and the sides were Scirocco 16v mounts; much heavier to deal with the extra weight.
I wonder if I trim off everything on the insert (other than the bottom 2 prongs), if it'll be tolerable. Otherwise I'll probably just run the standard that I bought and do the front & rear in poly.
-Todd
November 27, 2009, 02:31:25 pm
November 27, 2009, 02:31:25 pm »
I've been in a mk4 TDI (which uses a similar mouting style to a mk1) and he had full poly. It was honestly like sitting in one of those massaging chairs. Once the RPMs got up a bit it smoothed right out though. I don't think any CD player would have any chance of operating in that car.
In my mom's mk1 Jetta I put in new motor stock motor mounts and it's just fine. 1.6 NA w/ auto. It probably has less then 2000kms on it
Reply #11
November 27, 2009, 02:40:51 pm
Reply #11 on:
November 27, 2009, 02:40:51 pm »
i tried the rear mount on my jetta, the stiffness was nice, but the vibrations were insane, but i've read u can get away with polly everything but the rear with out it being too crazy. but i kind of doubt that.
Reply #12
November 27, 2009, 04:23:43 pm
ToddA1
Reply #12 on:
November 27, 2009, 04:23:43 pm »
I think I'll just stick with the standard stuff on the sides, and see how that is. I have a used poly rear, so I'll toss that on just to see what it's like, next.
-Todd
