Author Topic: Clutch question  (Read 3734 times)
November 22, 2009, 04:46:34 pm
1.9TD Caddy
Clutch question
« on: November 22, 2009, 04:46:34 pm »
Hi Guys, I replaced the clutch throwout bearing and installed a new clutch on the ACH transmission for my AAZ build.
I am pretty sure I have hooked up everything correctly.
The problem is with everything hooked up when I pull on the clutch release lever on the side of the tranny I dont feel any resistance. I t feels like the push rod is not pushing against the plate to release the clutch!!??
I pulled the tranny back off the engine and verified that the push rod moves out (about an inch) when the lever is pulled up.
Hooked it all back up...no resistance. What am I doing wrong? :(
Reply #1November 22, 2009, 04:50:07 pm
  • 3255
    • My collection of HOWTOs
Re: Clutch question
« Reply #1 on: November 22, 2009, 04:50:07 pm »
Here's the exploded picture... did you miss something perhaps?
Reply #2November 22, 2009, 05:08:19 pm
1.9TD Caddy
Re: Clutch question
« Reply #2 on: November 22, 2009, 05:08:19 pm »
Thanks for the picture. I will pull it apart again and recheck in the morning. If I missed something it must be on the clutch end because with the tranny removed I can see the push rod move when I move the lever. Thanks again.
Reply #3November 22, 2009, 05:31:03 pm
Black Smokin' Diesel
  • 656
Re: Clutch question
« Reply #3 on: November 22, 2009, 05:31:03 pm »
That plate (#14) could be missing or have a hole in it where the pushrod should rest.
91 Passat syncro 1.8T swapped.
Reply #4November 22, 2009, 06:43:56 pm
  • 3255
Re: Clutch question
« Reply #4 on: November 22, 2009, 06:43:56 pm »
Actually that's an interesting question... what was the clutch doing before that caused you to replace it?
Reply #5November 23, 2009, 07:01:25 am
1.9TD Caddy
Re: Clutch question
« Reply #5 on: November 23, 2009, 07:01:25 am »
Well, the engine and tranny were bought used and in pieces. After I tore every thing down for the rebuild the clutch looked worn....so thats the reason for the replacement. I just got done taking the tranny off and double checking everything. All looks good however the disc fig 14 has a small ding in it caused by wear from the rod pushing on it over time.
Any ideas will be much appreciated.
Reply #6November 23, 2009, 07:36:43 am
dennis
  • 311
Re: Clutch question
« Reply #6 on: November 23, 2009, 07:36:43 am »
Seen plate issues. Pressure plate not releasing? You can check that by trying to push the car while in gear. If seems like neutral I would think P.P. The rod can wear out too. Also there won't be any resistance on the lever untill the rod contacts the plate.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #7November 23, 2009, 07:48:49 pm
  • 656
Re: Clutch question
« Reply #7 on: November 23, 2009, 07:48:49 pm »
Something else to check is the "finger" that pushes on the pushrod. It's moved by the lever the clutch cable pulls on. If you remove the green cap at the end of the tranny you'll see it. It can crack and bend when it pushes against the throwout bearing.
http://www.brokevw.com/releasearm.html
Reply #8November 24, 2009, 04:09:07 am
1.9TD Caddy
Re: Clutch question
« Reply #8 on: November 24, 2009, 04:09:07 am »
Thanks to all for all the advice, Today I plan on removing the green cap at the end of the transmission and check on the size of the T/O bearing I replaced. From what I am reading it looks like there are two sizes of bearing. Hopefully it would be the wrong size bearing causing the problem...I keep you posted.
Reply #9November 25, 2009, 08:05:54 am
Re: Clutch question
« Reply #9 on: November 25, 2009, 08:05:54 am »
i bet the finger is broken. i just welded mine back together and closed my eyes. been working great.
