General Information
Troubleshooting
Tdi starter plus adapter question ?
Topic: Tdi starter plus adapter question ? (Read 6090 times)
November 21, 2009, 04:36:42 pm
Peter
November 21, 2009, 04:36:42 pm »
For my '86 Jetta ...Is it possible to use a starter from a TDI together with an adapter from
http://www.westyventures.com/images/tdistarteradaptor.jpg
or
http://westyventures.com/images/adaptor7.JPG
....if so, the starter would be self supporting and provide more torque/speed for turning over my "tired" motor
Last Edit: November 22, 2009, 06:40:56 am by Peter
November 22, 2009, 07:46:33 am
dieselherb1
Re: Tdi starter plus adapter question ?
November 22, 2009, 07:46:33 am »
I read somewhere the VR6 auto starter can be used with the TDI engine-trans. I'll have to try mounting a TDI starter on one of my 020 trans-engines.
November 22, 2009, 09:24:04 am
November 22, 2009, 09:24:04 am »
You might need to use the TDI front motor mount support as well (the one that the starter bolts through). I don't know though.
November 22, 2009, 09:26:07 am
Peter
November 22, 2009, 09:26:07 am »
obviously the links I gave above have to do with a vanagon..I thought I would ask the question since I don't have any "starters" to compare..I was hopeing someone had already looked into the possibilty of useing another type of starter..
Last Edit: November 22, 2009, 09:28:38 am by Peter
November 22, 2009, 09:35:10 am
November 22, 2009, 09:35:10 am »
The auto vr6 starter works,
http://www.vwdiesel.net/forum/index.php?topic=19781.0
November 26, 2009, 07:10:42 am
Peter
November 26, 2009, 07:10:42 am »
Quote from: burn_your_money on November 22, 2009, 09:35:10 am
..would it be possible if you could explain why the starter for an Automatic tranny will work as oppossed to a starter designed for the manual shift that will "not" work ..from other cars I have, there is no visible difference between the AT & Manual, except that one will draw more current then the other
General Information
Troubleshooting
