Author Topic: So how does this work??  (Read 5865 times)
November 20, 2009, 04:14:58 pm
« on: November 20, 2009, 04:14:58 pm »
Dodge Ram cummins drag racer
Notice how he's blowin' black in neutral? I can blow black just by flooring it for a second but he just goes on and on! And his turbo appears to spool up before he loads the engine. And then he goes kinda fast...... ;D
Reply #1November 20, 2009, 04:28:37 pm
Patrick
  • 1034
Re: So how does this work??
« Reply #1 on: November 20, 2009, 04:28:37 pm »
I'd bet he's running an automatic, truck is in gear with the brakes on. Needs time to heat things up so the turbo will spool..........
Reply #2November 20, 2009, 06:35:51 pm
rallydiesel
  • 1880
« Reply #2 on: November 20, 2009, 06:35:51 pm »
Not to mention he's probably running compound turbos with over 100 psi and retarded amounts of fuel being dumped into the cylinders.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3November 20, 2009, 06:48:12 pm
catlin_cava
  • 1954
« Reply #3 on: November 20, 2009, 06:48:12 pm »
His passenger side headlight has been removed and is being used as a ram air set up.
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #4November 20, 2009, 08:10:47 pm
« Reply #4 on: November 20, 2009, 08:10:47 pm »
ahhhh.........poor tranny :-\
Reply #5November 22, 2009, 04:20:05 am
Turbinepowered
  • 1206
« Reply #5 on: November 22, 2009, 04:20:05 am »
Life span measured in minutes.  >:(
Reply #6November 22, 2009, 05:09:08 am
« Reply #6 on: November 22, 2009, 05:09:08 am »
Only if your torque converter isn't up to the task.
What Is a Trans Brake?
Available for most popular automatic transmission applications from companies like TCI for between $400 and $500, a trans-brake conversion consists of a few (reversible) case modifications and a specially modified valve body that's equipped with an electric solenoid. A driver-operated pushbutton triggers the solenoid to move a shuttle valve, causing the transmission's hydraulic circuitry to engage First and Reverse gears at the same time. If this sounds like a recipe for self-destruction, remember the car is not in motion when the activation button is depressed. With the transmission input-shaft effectively locked, the driver then mashes the accelerator pedal to the floor, giving the torque converter no option other than to slip until its absolute stall speed is reached. When the light turns green, the driver releases the activation button and the car explodes off the line. Once moving, the driver upshifts the transmission in the usual way.
Reply #7November 22, 2009, 07:30:05 am
« Reply #7 on: November 22, 2009, 07:30:05 am »
You'll want to make sure you have some good tranny fluid and cooling capabilities.
