ANOTHER AAZ KO3 TURBO OIL RETURN LINE ( REPLACEMENT )
Topic: ANOTHER AAZ KO3 TURBO OIL RETURN LINE ( REPLACEMENT ) (Read 1957 times)
November 20, 2009, 10:30:12 am
GEE-BEE
November 20, 2009, 10:30:12 am »
TDIPARTS.COM has a replacement VW return oil line from The Turbo to the Block
Replaces banjo type assy
ITEM :028145736AE 90.95
Adapter replaces the banjo type fitting found on the stock hose assy
item: N90837101 6.92 EACH
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
