Author Topic: Bad injectors or wrong timing? Lack of power over 2800 rpm  (Read 3741 times)
November 20, 2009, 09:20:05 am
jbturgeon
  • 71
« on: November 20, 2009, 09:20:05 am »
Hi guys, i got  1.9 td with ac, 366500 km, and just got the head gasket done with timing belt and cleaning everything.. The problem is that i got this clicking ticking sound from my engine (injectors i suspect) on startup and at high rev (over 2800 rpm) and a lack of power over 3000rpm. There is white smoke as well over 3000 rpm. That is why i suspect the some injectors to be bad. I think my injectors (probably #3 or #4) are sticking or just got enough mileage on them to keep on going. I guess my timing is ok because it starts on the first crank at -5°C and i still got good mileage per tank. Also, i had to stick my wastegate on my turbo open all the time because the changeover valve don't open at high rev (another electric problem i guess!).
My question is where to start first:
1)Should i just leave it and my injectors will get fixed by themselves by shifting at very high rev (4500rpm) for a certain period of time!!
2)Getting my injectors rebuild;
3)Getting timing done on the Ip prior to a rebuild of my injectors or vice versa.
4)Anyone's sale used injectors?
Thx again
AAZ for life!
Subaru Loyale 4x4
Reply #1November 20, 2009, 09:48:50 am
Re: Bad injectors or wrong timing? Lack of power over 2800 rpm
« Reply #1 on: November 20, 2009, 09:48:50 am »
I'd start by checking the timing, then getting the injectors tested and take it from there.
Reply #2November 20, 2009, 10:04:17 am
jbturgeon
  • 71
« Reply #2 on: November 20, 2009, 10:04:17 am »
That's what i though. Can my Ip timing be off after a headgasket and a timing belt job? On the last post, i forgot to mention that the clicking sound was there before i did the gasket and t-belt. The other problem is that i have never done it... Time to give it a try i guess!!
AAZ for life!
Subaru Loyale 4x4
