corrado td tach
Topic: corrado td tach (Read 3163 times)
November 20, 2009, 06:26:49 am
54321chris
corrado td tach
November 20, 2009, 06:26:49 am »
Anybody know if the tachometer in my 1990 corrado is compatible with the W plug routine? Any advice is appreciated.
November 20, 2009, 08:07:27 am
Re: corrado td tach
November 20, 2009, 08:07:27 am »
it wont connect up thats for sure. if you modify it, then you might get it to work.
November 20, 2009, 06:25:42 pm
Black Smokin' Diesel
Re: corrado td tach
November 20, 2009, 06:25:42 pm »
It won't work but you could source a B3 TD gauge cluster. They pretty much are the same plus you'd get a glow plug light.
November 21, 2009, 12:50:38 pm
Faulty Logic
User+
Re: corrado td tach
November 21, 2009, 12:50:38 pm »
I picked up one of these on Ebay.........works perfect, slick little unit. Then you can run any gasser cluster you want.
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=128/prd128.htm
November 21, 2009, 03:42:03 pm
RadoTD
Stage WTF
Re: corrado td tach
November 21, 2009, 03:42:03 pm »
I've got a Corrado TD, using a 94 Jetta TD cluster.
There's a plug off of the diesel alternator with a red wire coming out of it. I ran that red wire and spliced it into U1/06 between the fuse box and the cluster.
Quote from: R.O.R-2.0 on July 24, 2011, 11:57:45 pm
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..
November 22, 2009, 05:03:53 am
54321chris
Re: corrado td tach
November 22, 2009, 05:03:53 am »
Thanks a lot, guys. I think I'll try the dakota digital interface, since I'd like to keep the cluster.
corrado td tach
