For Sale/Looking For
Parts for Sale/Wanted
WTB Miscellaneous 1.6 TD Engine Parts
Topic: WTB Miscellaneous 1.6 TD Engine Parts (Read 4737 times)
November 18, 2009, 04:20:48 pm
shwak23
1990 VW Golf TD. Engine Code CY
November 18, 2009, 04:20:48 pm »
OK what I really need is the cast manifold on top of the intake manifold and the rubber elbow that comes from the boost outlet of the turbo. I'll also need the oil supply line and the oil filter flange on the block. The oil return line and oil pan would be nice but I can probably make something.
http://i111.photobucket.com/al...D.jpg
November 18, 2009, 04:31:44 pm
cyrus #1
Re: WTB Miscellaneous 1.6 TD Engine Parts
November 18, 2009, 04:31:44 pm »
I may have some of those parts for you. What turbo are you using?
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
November 18, 2009, 04:37:15 pm
shwak23
November 18, 2009, 04:37:15 pm »
er. This turbo.
http://i111.photobucket.com/albums/n153/metricmeyham/TD.jpg
November 18, 2009, 04:50:12 pm
cyrus #1
November 18, 2009, 04:50:12 pm »
Well, the 1.6TD engines either came with a KKK K24 or a Garrett T3. Not all of the parts are interchangeable. You need to find the tag on the turbo or post a real picture of it and we can go from there.
The parts I have are for a T3.
Cody
2002 Jetta TDI
November 18, 2009, 04:52:02 pm
shwak23
November 18, 2009, 04:52:02 pm »
ah well here's a picture of my engine.
http://i710.photobucket.com/albums/ww106/shwak23/0618091836a.jpg
Does that help?
November 18, 2009, 05:07:28 pm
cyrus #1
November 18, 2009, 05:07:28 pm »
What is the engine code on that puppy and what exactly are you trying to put it into? That`s not a regular old transverse mounted 1.6TD, like what would come in a jetta.
That looks like a T3 turbo.
Cody
2002 Jetta TDI
November 18, 2009, 05:10:45 pm
shwak23
November 18, 2009, 05:10:45 pm »
Yeah it's a diesel out of a quantum. Hence why I need the parts. I'm putting it into a '90 golf. Everything is going well I just need these parts to make everything fit righttt.
November 18, 2009, 05:20:06 pm
cyrus #1
November 18, 2009, 05:20:06 pm »
I see. That helps clear things up a bit. Does that intake manifold have a block off plate or something for the elbow at the top, or do you need the whole manifold? That exhaust manifold isn`t the correct orientation for a golf either...
I have the following parts that you should be able to use.
-1.6TD intake manifold (or the elbow if you want)
-rubber elbow from turbo to intake
-oil feed line
-oil return line (slightly dented)
I also have the exhaust manifold and downpipe if you should need it. I will try to get some pictures up for you soon.
Cody
2002 Jetta TDI
November 18, 2009, 05:26:38 pm
shwak23
November 18, 2009, 05:26:38 pm »
Alrighty that's sweet. I don't need the manifold or down pipe as i've already sourced those locally. If you can get pics up tonight I can get money in your paypal shortly after.
November 18, 2009, 07:01:08 pm
cyrus #1
November 18, 2009, 07:01:08 pm »
Here are some pics of the goods.
Rubber intake elbow
Oil feed and return lines
Said denting on oil return line
Intake manifold with BOV assembly and intake elbow
Close up of intake ports
Cody
2002 Jetta TDI
November 19, 2009, 03:57:27 am
ilikevwdiesel
November 19, 2009, 03:57:27 am »
I've got a bunch of those parts and only 20 mi away. you can call me 897 4402 if you want.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
