Author Topic: What do you guys think of this lift pump?6-9psi  (Read 2641 times)
November 17, 2009, 02:06:05 pm
  • 3468
    • McScrubbins Body Wash
Reply #1November 17, 2009, 03:01:58 pm
maxfax
  • 2126
Re: What do you guys think of this lift pump?6-9psi
« Reply #1 on: November 17, 2009, 03:01:58 pm »
I've used those on my gassers and diesels with good results..
I had one on my WVO for a while, but I suspect it didn't enjoy the heat as it died pretty quick...
I didn;t use the screw in filter they sent though... I think it was actually causing some restriction..
Reply #2November 17, 2009, 07:27:16 pm
« Reply #2 on: November 17, 2009, 07:27:16 pm »
"FLOW: 10GPH @ 9 V STARTED"
That seems on the low side of things to me, especially on a hopped up diesel
Reply #3November 18, 2009, 02:07:46 am
  • 3468
« Reply #3 on: November 18, 2009, 02:07:46 am »
all i see is 10 gallons per hour which is significantly more fuel that i think i can burn in an hour ...
what does that @ 9 V started mean?
Reply #4November 18, 2009, 08:18:43 am
« Reply #4 on: November 18, 2009, 08:18:43 am »
10 gph at 9 volts...
thats really low... but it will probably work.
Reply #5November 18, 2009, 08:42:33 am
« Reply #5 on: November 18, 2009, 08:42:33 am »
Don't forget the VE pump sends MOST of the fuel back down the return and only injects a small amount.  The extra fuel is used to cool the pump.
Reply #6November 18, 2009, 08:59:38 am
blackdogvan
  • 574
« Reply #6 on: November 18, 2009, 08:59:38 am »
I googled them, didn't take long to find a WVO forum where they were being discussed in detail. Thats the old model, noisy & 10% failure rate. There is a newer plastic shelled unit that apparently fails less & is still noisy.
1991 Vanagon 1.9 mTDI
