Author Topic: AAZ pump landed.....take 2  (Read 2284 times)
November 14, 2009, 12:43:16 am
tunedbandit
  • 47
« on: November 14, 2009, 12:43:16 am »
Reply #1November 14, 2009, 06:59:44 am
Re: AAZ pump landed.....take 2
« Reply #1 on: November 14, 2009, 06:59:44 am »
Do you want me to delete one of those threads?
Reply #2November 14, 2009, 02:30:00 pm
tunedbandit
  • 47
« Reply #2 on: November 14, 2009, 02:30:00 pm »
cheers mate if you could that would be great thanks
i kinda uploaded up the aaz pump wrong  :-[
its "Take 2" i wanted up
cheers Rick  :)
Reply #3November 14, 2009, 03:55:13 pm
« Reply #3 on: November 14, 2009, 03:55:13 pm »
Done and done.
What are you showing off in picture#2 with that red circle?
It looks like you've fitted a 1.6 pin into the pump?
Reply #4November 15, 2009, 12:00:43 am
tunedbandit
  • 47
« Reply #4 on: November 15, 2009, 12:00:43 am »
thanks for getting rid of my mistake
yeah the pics are of my new/old aaz pump ive just bought to fit to my T4 1.9TD 2001
the picture with the red circle is where someone as used a hammer to remove the pulley & i was wondering whether it may cause any internal bearing damage to the pump,,its a rubbish picture but its got a dent on the pulley,,also was wondering whether ive got all the required parts to do the conversion as someone on another forum who as done theres as mentioned   "Do You Have The Bracket"
i would of thought it would bolt straight to the block & all the bolts on mine would do,,all the pictures you see is of the parts i have,,iam going to see if there's a bosch service kit Eg: seals/gaskets/bearings & what not before i fit the pump,,as for the boost pin its what came with the pump & the seller had a spare LDA top  "Adjustable Top Type"   but by the looks of it the "None Adjustable Top" looks like you could remove the pressed cover as its exactly the same as the tutha one.
cheers Rick
