Author Topic: Wanted 1.6 TD fuel pin spring.  (Read 4826 times)
November 11, 2009, 10:38:25 am
allsierra123
« on: November 11, 2009, 10:38:25 am »
I need a 1.6 TD fuel pin spring Or a stiffer spring I can use in my rover pin upgrade.
Reply #1November 11, 2009, 11:03:45 am
burnt_servo
  • 278
Re: Wanted 1.6 TD fuel pin spring.
« Reply #1 on: November 11, 2009, 11:03:45 am »
this is kind of  off topic , but i think it might help you .
i've run into 2 colours of springs ( i think there are more )a bluish green and a white spring . the white spring being the stiffer of the 2 .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
Reply #2November 13, 2009, 09:55:53 am
allsierra123
« Reply #2 on: November 13, 2009, 09:55:53 am »
anyone have one or know if i can buy them from somewhere?
Reply #3November 13, 2009, 10:16:42 am
GEE-BEE
  • 1604
« Reply #3 on: November 13, 2009, 10:16:42 am »
BRICKWERKS.COM , Iam sure he can help you
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #4November 13, 2009, 08:23:25 pm
allsierra123
« Reply #4 on: November 13, 2009, 08:23:25 pm »
Was hoping to find somewhere in the states to pick it up.
Reply #5November 14, 2009, 04:05:14 pm
« Reply #5 on: November 14, 2009, 04:05:14 pm »
Giles will probably sell you one ???
