Author Topic: WTB used AAZ vacuum pump  (Read 3830 times)
November 10, 2009, 11:30:10 am
passatdiesel
  • 19
« on: November 10, 2009, 11:30:10 am »
Sheered off the plastic piece on my vacuum pump to the line that runs over to the brake booster. Tried using some compound to reattach it, but with no success. Was hoping someone had a worn out pump i could rob some parts off.
Any other suggestions would be great. Went to our local wrecker only to find a 1.6D that had a rotory pump too small for the AAZ.
Reply #1November 10, 2009, 11:44:02 am
neimis
  • 75
Re: WTB used AAZ vacuum pump
« Reply #1 on: November 10, 2009, 11:44:02 am »
Do you mean the check valve? The plastic nipples on it get brittle from age and heat and snap off very easily when you try to remove the vacuum lines. You can buy a new check valve with molded on brake booster hose from dealer for about $50. If you go to a junkyard, all the valves are broken or the hose has been cut...
Hope this helps
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #2November 10, 2009, 12:24:42 pm
sawedoffgolf
  • 213
« Reply #2 on: November 10, 2009, 12:24:42 pm »
Not sure if this is the kind you need or not? if so im heading up to edmonton this upcoming saturday ;)
Reply #3November 10, 2009, 04:52:39 pm
GEE-BEE
  • 1604
« Reply #3 on: November 10, 2009, 04:52:39 pm »
I HAVE A  EXTRA PUMP 100.00 SHIPPED, PERFECT CONDITION
LET ME KNOW...
GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
