Author Topic: Losing Prime again and again....MTDI AHU  (Read 3499 times)
November 10, 2009, 07:43:24 am
avocado
« on: November 10, 2009, 07:43:24 am »
Hi
I put a AHU in a Suzuki Sidekick.  Bought amanual pump from a fellow on here and the little truck runs great!  Well...most of the time.
It seems to lose prime at really weird times.
I recently put a clear fuel line (  5/16") between the fuel filter and the pump in order to see what the hell is going on.  I have found that sometimes after sitting the fuel line is completely empty of fuel.  I cannot figure out where the air is coming from...all lines are tight and new.
I was wondering if the fuel is just pulling out of the line (air coming from the IP side after shutdown?) and going back into the tank.
Should I put a check valve in the line at the tank to make sure fuel is only going to the engine and not back into the tank?
Reply #1November 10, 2009, 03:46:04 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: Losing Prime again and again....MTDI AHU
« Reply #1 on: November 10, 2009, 03:46:04 pm »
check the injector return lines, and other return lines. when swtiched off, it will allow air in and all the fuel will drain backwards.
'91 Golf Cabrio 1.9TD
Reply #2November 11, 2009, 10:20:14 am
avocado
« Reply #2 on: November 11, 2009, 10:20:14 am »
Wouldn't it be easier to just add a check valve?
The thing is that I remember having put my return line into the tank at a pretty high level, so it may be sucking air from back in the tank...
Reply #3December 02, 2009, 08:17:24 pm
D.Loops
  • 7
    [url=http://tierussianwoman.w-ru.com/]wife of a russian[/url]
    • ukrainian marriage
Losing Prime again and again MTDI AHU
« Reply #3 on: December 02, 2009, 08:17:24 pm »
air in the fuel would be a problem for starting must be sucking air from somewhere or fuel could be leaking back to tank could try a non return valve?
Reply #4December 02, 2009, 10:57:22 pm
westyventures
  • 45
« Reply #4 on: December 02, 2009, 10:57:22 pm »
Check the pump shaft seal.
Karl Mullendore
www.westyventures.com
