Timing Question...1.6L N/A
Topic: Timing Question...1.6L N/A (Read 2937 times)
November 09, 2009, 08:28:23 pm
ted.hight
Newbie
November 09, 2009, 08:28:23 pm »
So my engine is going through its winterly tissy and will not start, unassisted, when cold. I asked about it and you guys said check the timing and the compression. (Everything else is seemingly working. New fuel filter, new plugs, etc...) Since I don't really know much theory behind the timing of a diesel I have a question; Why would the timing go from perfectly in time, to so bad it will no longer start in the morning?
Also, what are the symptoms of air in the fuel supply? And what are the causes/probable leaky spots?
Thanks!
November 09, 2009, 08:38:34 pm
Re: Timing Question...1.6L N/A
November 09, 2009, 08:38:34 pm »
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
This is a great write-up about setting the timing and a little bit about the concept.
The belt may have slipped a tooth, causing it to be really whack.
Air in the fuel supply will cause a rough running (even if it will run judging on the amount of air), and hard starting if the pump is loosing its prime.
November 09, 2009, 08:46:53 pm
ted.hight
Newbie
November 09, 2009, 08:46:53 pm »
I'm pretty sure the belt didn't slip a tooth, the car runs very well once it starts up. I wonder if I need to chase this air in the fuel idea. Where are possible leak points? The return lines?
November 09, 2009, 09:02:47 pm
rabbitman
November 09, 2009, 09:02:47 pm »
Your glows are for sure glowing?
November 09, 2009, 09:44:45 pm
ted.hight
Newbie
November 09, 2009, 09:44:45 pm »
Yeah. I tested each of the plugs on the battery and all glowed red hot in a few seconds. They are also getting power to the plugs for the 20ish seconds before the relay shuts them down.
November 10, 2009, 05:48:41 am
macka
November 10, 2009, 05:48:41 am »
Check your bus bar, they are notoriously bad for failing. You should pimp your plugs, it makes for starts that take 1 or 2 seconds of starter use.
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
November 10, 2009, 07:53:04 am
rodpaslow
November 10, 2009, 07:53:04 am »
The bus bar is? I'm assuming this is the bar that connects all the glow plugs together at the front of the engine?
To pimp them you use what gauge wire?
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
November 10, 2009, 07:54:21 am
November 10, 2009, 07:54:21 am »
http://vincewaldon.com/index.php?option=com_content&task=view&id=30&Itemid=28
November 10, 2009, 10:12:29 am
rodpaslow
November 10, 2009, 10:12:29 am »
Thanks
November 15, 2009, 01:19:29 pm
ted.hight
Newbie
November 15, 2009, 01:19:29 pm »
So I have a dummie alert: It was the screws holding down the GP fuse.
So a huge head ache for a minor problem. The glow plugs were getting power but just not enough as the screws were not making very good contact with the fuse. Oh well! Thanks for all the help guys!
Ted
