Author Topic: CV Drive shafts 90mm to 100mm swap  (Read 10591 times)
November 05, 2009, 07:02:12 am
1.9TD Caddy
« on: November 05, 2009, 07:02:12 am »
Hello All,
I am installing an 5 speed ACH transmission in my 81 rabbit P/U diesel. The new tranny  has the 100mm drive flanges. What drive shafts will work on the Rabbit P/U with an ACH 100mm drive shaft flange tranny. I am thinking of going over to the local scrap yard and pulling the drive shafts of off a 5 speed 1986 Jetta. Will it work?
Thanks!
Reply #1November 05, 2009, 07:17:42 am
Re: CV Drive shafts 90mm to 100mm swap
« Reply #1 on: November 05, 2009, 07:17:42 am »
mk1 drive shafts fit in MK1's the only bolt in shaft you can use is out of a 16v scirocco. or just put some 100mm inners on the axles you already have. thats what i did. took a trans and inner cv joints from a 92 jetta and put them in my 81 rabbit. the inner CV joints will work, the whole jetta/golf axle wont.
Reply #2November 05, 2009, 08:04:36 am
rodpaslow
  • 670
« Reply #2 on: November 05, 2009, 08:04:36 am »
There is another option with a newer trans, at least in Canada, mk2 85-92 na deisel cars (most) came with 90mm transmission flanges that fit properly with a newer 85 + up 020 transmission.  The TD's mostly came with 100mm.  I actually have a couple.  All you need to do is remove the 100mm flanges and install the 90mm.
Reply #3November 05, 2009, 08:29:19 am
1.9TD Caddy
« Reply #3 on: November 05, 2009, 08:29:19 am »
Thanks! Great ideas!!! I think I will just swap out the inners.
Thanks!
Reply #4November 05, 2009, 05:05:37 pm
MizpahPAH
  • 27
« Reply #4 on: November 05, 2009, 05:05:37 pm »
Do you'all replace the C clips that hold the flanges to the output shafts on the trans each time or are they resuable
Reply #5November 05, 2009, 06:17:51 pm
GEE-BEE
  • 1604
« Reply #5 on: November 05, 2009, 06:17:51 pm »
I had to do the opposite with my 100 mm new axle's, my trans was 90 mm , so I purchased some new 90mm inners
So i have a new set of 100 mm's now
1981 mk1 Caddy, I purchased new 100 mm axles for a 16v Scirocco
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #6November 06, 2009, 04:34:21 am
1.9TD Caddy
« Reply #6 on: November 06, 2009, 04:34:21 am »
Just curious. What year 16v  scirocco drive shafts will fit 1981 caddy with 100mm drive?
Reply #7November 06, 2009, 08:04:28 am
« Reply #7 on: November 06, 2009, 08:04:28 am »
ANY scirocco with a 16V. im not sure of exact years. i know that the 16v didnt come out till 86 tho.
Reply #8November 06, 2009, 09:42:31 am
GEE-BEE
  • 1604
« Reply #8 on: November 06, 2009, 09:42:31 am »
CORRECT !
Giles Pump OHC
MK1 JETTA DASH
Reply #9November 06, 2009, 01:03:37 pm
arb
« Reply #9 on: November 06, 2009, 01:03:37 pm »
I reused mine, but its only been a few months.
Reply #10November 07, 2009, 07:12:51 am
« Reply #10 on: November 07, 2009, 07:12:51 am »
i never re used my clips. when i did my conversion, i had 92 Jetta inner CV joints. not 80's 16v scirocco. i had to tack weld my CVs to my axles. they were just the slightest bit too thick, so i couldnt get the hardware to go on over them. so i put a couple tacks on them. they are not serviceable, but they work like a dream, and dont shake.
