Author Topic: Ebay timing tools  (Read 11454 times)
November 03, 2009, 08:01:35 am
ToddA1
  • 434
Ebay timing tools
« on: November 03, 2009, 08:01:35 am »
I thought I read a thread where people mentioned a particular Ebay seller, for the camlock, pump lock, and the dial gauge.  I think the seller offered all 3 in an inexpensive package; I can't seem to find it, now.
Any ideas or personal experiences with any of them?
-Todd
P.S.
I've read Vince's excellent write up (many times), so I figure I'll need at least the gauge. This will be my 1st time timing a diesel.
Reply #1November 03, 2009, 09:22:12 am
Wayland
  • 364
Re: Ebay timing tools
« Reply #1 on: November 03, 2009, 09:22:12 am »
I bought mine off ebay from Prothe. It appears to be home made, but the quality is good enough. It works great and was quite cheap, although I can't remember exactly how much.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2November 03, 2009, 09:47:38 am
macka
  • 957
« Reply #2 on: November 03, 2009, 09:47:38 am »
For a cam lock, I used a 3 inch door hinge. For the fuel pump pulley I used a chunk of barstock I had. I eyeballed timing  :o . I don't recommend eyeballing the timing.
Quote from: Vincent Walden
Reply #3November 03, 2009, 11:27:44 am
Turbinepowered
  • 1206
« Reply #3 on: November 03, 2009, 11:27:44 am »
This seller and kit has an excellent reputation.
Reply #4November 03, 2009, 07:40:10 pm
maxfax
  • 2126
« Reply #4 on: November 03, 2009, 07:40:10 pm »
Reply #5November 03, 2009, 08:16:02 pm
ToddA1
  • 434
« Reply #5 on: November 03, 2009, 08:16:02 pm »
That's the exact set that I was looking for.....  Thanks!
-Todd
Reply #6November 03, 2009, 08:58:17 pm
Baron VonZeppelin
« Reply #6 on: November 03, 2009, 08:58:17 pm »
x3 on that kit.
It is excellent quality, and metric scaled too.
Reply #7November 12, 2009, 08:09:56 am
ToddA1
  • 434
« Reply #7 on: November 12, 2009, 08:09:56 am »
Kit arrived and looks very high quality.
One question...  what's the black oxide bolt used for?  I think 8x1.25 and it's alled head.  I didn't see the Bentley mention it.
-Todd
Reply #8November 14, 2009, 10:16:33 am
« Reply #8 on: November 14, 2009, 10:16:33 am »
I think it's a one time use tool for practicing your basketball moves. Just take aim at the nearest scrap metal bin.
Reply #9January 03, 2010, 10:00:54 pm
mtnsammy
  • 97
« Reply #9 on: January 03, 2010, 10:00:54 pm »
3 cheepo sets and now finally a good quality tool. Thanks for the post.
Reply #10April 28, 2010, 09:48:10 am
« Reply #10 on: April 28, 2010, 09:48:10 am »
Does anyone have the username of the seller in the above Ebay link?
Reply #11April 28, 2010, 12:50:33 pm
ToddA1
  • 434
« Reply #11 on: April 28, 2010, 12:50:33 pm »
rdigerb5315
-Todd
Reply #12April 28, 2010, 06:20:55 pm
« Reply #12 on: April 28, 2010, 06:20:55 pm »
Reply #13May 14, 2010, 11:33:55 pm
Baron VonZeppelin
« Reply #13 on: May 14, 2010, 11:33:55 pm »
Every so often this seller (aka - german guy on eBay) will put a set up for auction. I have seen a few folks get REAL LUCKY ($20-40 plus ship).
So, if you're going to be in the market for a set eventually, but not in a rush - keep an eye on his listings regurlarly.
http://shop.ebay.com/rdigerb5315/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
Another VERY worthwhile tool is a timing belt tension measurement tool. It measures the tension on the belt. (NOT talking about the 2-pin tool that adjusts the tensioner)
I was very surprised at the amount of slack at the VW Factory recommended 12-13 units. I would have all of mine overtightened to some degree by now. And wearing out intermediate bearings/deducting lifespan from engines.
HUGE peace of mind knowing the tension is Spot-On !
« Last Edit: May 14, 2010, 11:41:44 pm by Baron VonZeppelin »
Reply #14May 14, 2010, 11:37:47 pm
Baron VonZeppelin
« Reply #14 on: May 14, 2010, 11:37:47 pm »
-Todd
On some applications it can be used to knock the cam sprocket loose. But not on our A1 A2 stuff. I use a 6mm bolt. But you "could" drill/ream the hole in the timing cover out to 8-9mm and use the larger bolt. Probably wouldn't be such a bad idea either.
