Author Topic: Dieselicious Turbocharger Upgrade/Rebuild Kits  (Read 100035 times)
Reply #30April 05, 2006, 06:35:27 pm
ancient
« Reply #30 on: April 05, 2006, 06:35:27 pm »
Hi Jake, do you have a rebuild kit for Vnt-15 or vnt-17 turbo?  thanks.
Quote from: "fspGTD"
Let me know when you are interested; I hope to be offering these parts for a while.  Look for other VW peformance parts coming from me in the near future as well! :)
Just remember that running a turbo until it stops working, IE: when the wheels hit the housings, will leave it needing much more than a rebuild kit but also possibly new shafts, wheels, housings, and other major parts, which are not always available and can get expensive!  It is a wise strategy to rebuild high-mileage or hard-used turbos preventatively.
Reply #31April 09, 2006, 12:41:38 am
fspGTD
  • 1529
    • http://home.comcast.net/~vwgtd
« Reply #31 on: April 09, 2006, 12:41:38 am »
I IM'ed you, would love to help with a VNT kit!
Remember folks: to ensure I get you the right parts for any special requests, I need your turbo model number, which can be found on a turbo's identification plate.  Thanks!
Jake Russell
Reply #32April 26, 2006, 06:27:22 pm
jcVerville
« Reply #32 on: April 26, 2006, 06:27:22 pm »
Hi I have a 94 1.9 TD with small ***ty K03 Im looking for K24 + manifold!! to fit my engine. i'd like to know if you have some??
And for K03 do you have something to make it more powerful?? I know I can't go over 15 PSI or the wastegate may stay open. :( and the K24 you can go 25 PSI :)
Reply #33May 15, 2006, 08:40:28 am
houseofdiesel
  • 210
« Reply #33 on: May 15, 2006, 08:40:28 am »
Can you source a rebuild kit for a K03-006/97818 (oe # 028-145-701J 98 Jetta AHU TDI) turbo? It was oil starved-big time shaft play and looks like some fins might be slightly bent...
Also for a K14 7009 92 534 0564 (oe 028-145-703E) just the upgraded parts.
Greg
Reply #34May 15, 2006, 08:26:22 pm
fspGTD
  • 1529
« Reply #34 on: May 15, 2006, 08:26:22 pm »
Greg - I may have kits in stock that will work for these applications, but I need to do some research on the part numbers to make sure.  Let me look into this and I'll get back to you.  Thanks!
jcVerville - I don't have any extra K24s currently available.  I'd suggest searching the classifieds section, and if no luck posting a "wanted to buy" thread in there.
Jake Russell
Reply #35May 17, 2006, 12:00:37 pm
Maarten
  • 339
« Reply #35 on: May 17, 2006, 12:00:37 pm »
How much is the shipping to The Netherlands?
Do you sell shafts and compressorwheels too? (I bought a K24 with a damaged compressorwheel and shaft)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #36May 31, 2006, 08:16:42 pm
fspGTD
  • 1529
« Reply #36 on: May 31, 2006, 08:16:42 pm »
Hey Maarten - unfortunately replacement wheels are not available for the 1.6lTD KKK K24 application.
I can ship one of my normally stocked Dieselicious turbo rebuild kits to Europe for $10 US.
Jake Russell
Reply #37August 28, 2006, 06:11:51 pm
WesNye_ScienceGuy
  • 1
« Reply #37 on: August 28, 2006, 06:11:51 pm »
Email sent. Thanks
NOx ROCKS MY SOCKS!
Reply #38September 08, 2006, 06:23:19 pm
starrd
  • 128
« Reply #38 on: September 08, 2006, 06:23:19 pm »
Jake, Email sent.
Thanks Don
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #39September 08, 2006, 06:25:17 pm
cubevandude
  • 11
« Reply #39 on: September 08, 2006, 06:25:17 pm »
Is there a way to see the plate without removing the turbo?
91 Jetta TD
Reply #40September 08, 2006, 11:54:58 pm
LeeG
  • 401
« Reply #40 on: September 08, 2006, 11:54:58 pm »
On my '91 I had to pull the rubber turbo-manifold tube and unbolt a heat shield from above turbo, then I had a good view of the tag on my KKK.  Some cars got Garret turbos, not sure where their tag is.
'97 Passat TDI
Reply #41October 03, 2006, 10:55:30 pm
mercedesjones
  • 7
aaz kkk
« Reply #41 on: October 03, 2006, 10:55:30 pm »
Hi, do you still have kits for the 1.9 kkk? If so i'd like one.
Cheers,
Reply #42October 10, 2006, 05:33:28 pm
Spulen81
  • 103
« Reply #42 on: October 10, 2006, 05:33:28 pm »
You have email. Thanks
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #43October 11, 2006, 02:31:03 am
scopefrfd
  • 289
« Reply #43 on: October 11, 2006, 02:31:03 am »
interested in a K14 rebuild kit
Reply #44October 11, 2006, 02:31:38 am
scopefrfd
  • 289
« Reply #44 on: October 11, 2006, 02:31:38 am »
also any ve pump seal kits?
