Author Topic: Emergency Seatbelt  (Read 5042 times)
October 22, 2009, 12:58:30 am
Emerald Energy
  • 25
Emergency Seatbelt
« on: October 22, 2009, 12:58:30 am »
Has anyone sucessfully bypassed the emengency seatbelt on a 91 jetta. I have a short in the mechanism attached to the door and it is causing starting issues. I'm wondering if there is a way to bypass that circuit or to connect the two wires together if it will let the car start or what happens?
Thanks for any help.
Reply #1October 24, 2009, 06:23:49 am
spencebm
  • 686
Re: Emergency Seatbelt
« Reply #1 on: October 24, 2009, 06:23:49 am »
splice the two wires together, never had a problem after that
Ben Spencer
Reply #2October 29, 2009, 07:12:18 pm
Emerald Energy
  • 25
« Reply #2 on: October 29, 2009, 07:12:18 pm »
Thanks I'll give it a try.
Reply #3November 02, 2009, 03:14:09 pm
Turbinepowered
  • 1206
« Reply #3 on: November 02, 2009, 03:14:09 pm »
I took the whole system's power wire and used that as my "keyed on" power supply for my stereo. No more annoying sounds.  ;D
Reply #4November 02, 2009, 08:04:38 pm
  • 2931
« Reply #4 on: November 02, 2009, 08:04:38 pm »
 That goes on when the key is inserted?
 My '91 Golf has a relay for that, so I can listen to the radio without the key on.
 but on earlier ones the radio shut off when the engine did.
 Good idea.
 To the original poster; I found the relay and jumped the wires going into the back; from the ignition> to the starter.
Reply #5November 05, 2009, 05:48:40 am
Emerald Energy
  • 25
« Reply #5 on: November 05, 2009, 05:48:40 am »
I just did as suggested(crimp the two wires together) and the car starts fine, also no more annoying buzzer when you open the door with the keys in the ignition!
