Author Topic: more 1.6 TD vs 1.9 TD  (Read 2542 times)
October 05, 2005, 06:48:22 am
larry104
  • 200
« on: October 05, 2005, 06:48:22 am »
I'm new to VW diesels. I've driven Hondas for years and have gotten 42 mpg from my '93 Civic EX. I'm used to 125 hp and a 6,500 rpm redline, so a diesel is going to be an adjustment. But I've always been intrigued by diesels and want to give one a try. I'm also considering a vegetable oil conversion. I've read some of the material on this board, which is a great resource by the way. Anyhow, I'm looking at a 1986 Jetta 1.6 NA and I want more power. I'd like to drop in a 1.9 L TD. I understand there are some differences in motor mounts, but it seems pretty straightforward. My question is, is it worth doing? Would it make more sense to find a 1.6 TD instead? Is the difference in performance that noticeable? Does anyone have hp/torque numbers on these motors? I also get the impression that 1.9 L motors are harder to find parts for and they more expensive than for the 1.6 L, especially in the U.S. What's been your experience? Thank you.
Reply #1October 05, 2005, 08:52:03 am
VWRacer
  • 649
« Reply #1 on: October 05, 2005, 08:52:03 am »
Larry, as you probably know by now, the 1.9TD was never imported to the USA. They can be found, but not easily. Since you are new to diesels and presumably VW's, I suggest you consider the 1.6TD route for a first iteration. The 1.6 N/A can be made into a fair machine, with a high rev limit, but it will never compete with an equally well prepared 1.6TD. Pass on the 1.6 and find a TD. 'Nuf said.
As you continue to read threads you will eventually find that 100 hp and 6500 rpm are doable with a well built 1.6TD, taking advantage of all the advances laid out on these pages. That may seem a bit down on power compared to the Honda, but since you'll be developing twice the torque I am confident you'll not be disappointed.
Good luck with your project!  :D
Stan
C-Sports Racer
Reply #2October 05, 2005, 06:45:17 pm
larry104
  • 200
Thanks, VWRacer...
« Reply #2 on: October 05, 2005, 06:45:17 pm »
...much appreciated. Sounds like the 1.6 TD is the way to go.
