Author Topic: I have adjusted the 1.6td pump, how do I turn the boost up?  (Read 2863 times)
October 06, 2009, 03:49:04 pm
xtrigger
  • 48
    d3lahk
« on: October 06, 2009, 03:49:04 pm »
I have increased the fuel screw, and the top screw ( I guess smoke screw) car moves alot better but smoky, im wondering what I need to do to increase the boost?
I know smoky black isnt good, as that means high EGT, Cant I combate that with more boost?
its an 86 1.6td
thanks
1986 VW Jetta TDI
Reply #1October 06, 2009, 09:12:39 pm
rallydiesel
  • 1880
Re: I have adjusted the 1.6td pump, how do I turn the boost up?
« Reply #1 on: October 06, 2009, 09:12:39 pm »
You should read the 1.6td Faster car thread in the FAQ. It will answer most of your questions. In the mean time, you will need to buy/make a boost controller in order to increase boost. And yes, adding more boost can clear up the smoke.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 07, 2009, 09:41:09 am
xtrigger
  • 48
    d3lahk
« Reply #2 on: October 07, 2009, 09:41:09 am »
I read the entire FAQ, where do I took it up the MBC?
it just says to install one, doesnt say were...
I have a poppett type WG, So run the line from the WG to a MBC, block off the port on the turbo were the line used to go, then run the other side of the line to were the boost is seem on the intake... i just want to make sure IM right... like a standard gassser turbo setup
thanks
1986 VW Jetta TDI
Reply #3October 07, 2009, 11:08:47 am
rallydiesel
  • 1880
« Reply #3 on: October 07, 2009, 11:08:47 am »
You could do that, or just cut the line going to the wastegate can and splice in the MBC.
Reply #4October 07, 2009, 04:51:49 pm
xtrigger
  • 48
    d3lahk
« Reply #4 on: October 07, 2009, 04:51:49 pm »
alright I got it, thanks
1986 VW Jetta TDI
