1.6 Turbo question
Topic: 1.6 Turbo question (Read 3237 times)
October 06, 2009, 07:29:15 am
Emerald Energy
User+
1.6 Turbo question
October 06, 2009, 07:29:15 am »
I have a 91 Jetta TD and want to know what turbo came from the factory and if I want to upgrade what turbo sizes are bolt on's?
Thanks-
October 07, 2009, 07:51:15 am
Emerald Energy
User+
Re: 1.6 Turbo question
October 07, 2009, 07:51:15 am »
Any turbo experts out there?
October 07, 2009, 01:03:21 pm
Powered by Spearco
October 07, 2009, 01:03:21 pm »
If its a stock engine, then its a "KKK K24" or a "Garrett T3".
Look at the waste gate. If it looks like a metal can, then its a Garrett, if it looks finned and cast, its a KKK.
Or you could just look at the ID. tag between the compressor housing and center housing
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
October 07, 2009, 02:17:23 pm
smutts
ClackClackClackClackClack
October 07, 2009, 02:17:23 pm »
KKK K14 is also likely.
October 08, 2009, 12:38:13 am
Emerald Energy
User+
October 08, 2009, 12:38:13 am »
Ok, both of my engines are KKK's. What size/type of turbo's fit that I can upgrade to? I'm used to old school Chevy 350's so excuse all the dumb questions....
October 08, 2009, 06:53:53 am
October 08, 2009, 06:53:53 am »
Well, none really without changing over the manifold or fabbing an adapter. VW used a special trapezoidal flange on the 1.6 diesels. Some people say you can get more boost out of the Garret turbo over the K24.
'86 Golf N/A Diesel -->Wife's car
October 08, 2009, 10:27:29 am
Emerald Energy
User+
October 08, 2009, 10:27:29 am »
One of my engines is an ECO and one of them is not. I have no idea about boost. The non-ECO I want to bore .040" over and get a bigger turbo, but now I need details on how to increase the boost pressure or buy a bigger turbo.
October 08, 2009, 11:52:59 am
VelocityConservation
October 08, 2009, 11:52:59 am »
EE,
LibbyBapa is really asking, "what does 'bigger' mean to you?"
Diesels are relatively low RPM engines. As a result when discussing turbo's bigger does not always mean better.
I have a k-24. It is in stock form, so the wastegate opens at around 12psi. It starts making significant boost at 2k rpm. I would expect your K-14 to start making boost earlier in the rpm range (which I think would be more desireable with a diesel motor) and still have no trouble getting to where the stock wastegate opens. Installing a boost controller would allow you to make more boost.
I think there are lots of other updates you should make before increasing the boost. I had Myke_W put ARP head studs and the metal head gasket in when he built my new long block this year.
90 TD Jetta, NA to TD swap completed '07
October 09, 2009, 12:21:50 am
Emerald Energy
User+
October 09, 2009, 12:21:50 am »
My overall goal is to build a "Show and Go" car. One that has great throttle and topend. The twist is that it will do all this while running on 100% Biodiesel and SVO. I know it wont be the same as with a gas car but I would like it as close as possible. REally I want a Kick a$$ car to promote the use of biodiesel. Most people around here think of slow old worn out farm trucks or black clouded Volvo's when they think of diesels. My idea is to change the locals ways of thinking... What do I need to achieve that?
October 09, 2009, 05:51:30 am
October 09, 2009, 05:51:30 am »
http://www.vwdiesel.net/forum/index.php?topic=19591.0
I would also check the faq for making your 1.6 a faster car. That will help you on the engine to get it to go. Also the vendors section has some dealer for go fast parts. As far as show you could put your engine in a 32 ford coupe
Really though any body shop advice for any car would fit the bill.
Round 2
1.6 Turbo question
