Author Topic: Lucas Cav Pumps  (Read 10266 times)
October 05, 2009, 07:45:38 am
anto
Lucas Cav Pumps
« on: October 05, 2009, 07:45:38 am »
Would anyone have a rebuild guide for a lucas cav pump?
Very little info on these compared to the bosch pumps, but surely someone has opened one up?
Any help greatly appreciated,
Thanks
Anton
Reply #1October 13, 2009, 05:29:42 am
anto
Re: Lucas Cav Pumps
« Reply #1 on: October 13, 2009, 05:29:42 am »
Obviously not a very popular pump compared to the bosch pumps.....
Very little info on it in the www.
Anyone any links to any little snippets of info on these pumps?
Reply #2October 13, 2009, 06:22:51 am
Patrick
  • 1034
Re: Lucas Cav Pumps
« Reply #2 on: October 13, 2009, 06:22:51 am »
I'd like some info too........
I've had the governor body apart on on (Hydraulic governor) because of a fuel leak (Bad o-ring) but haven't been any farther.
Reply #3November 16, 2009, 07:20:37 am
Zulfiqar
  • 254
Re: Lucas Cav Pumps
« Reply #3 on: November 16, 2009, 07:20:37 am »
rule 1 of diesel engines
if it says BOSCH and its diesel - your grandchildren will also be using it
if LUCAS - you will throw it away and swap to bosch before you die
rule 1 of car electrics
if a product says lucas - expect failure at the worst moment - like your car forcing you late for work and your boss firing you.
Diesel IS the future
Reply #4November 16, 2009, 11:00:29 am
Re: Lucas Cav Pumps
« Reply #4 on: November 16, 2009, 11:00:29 am »
Lucas fuel additive is pretty good stuff. but im pretty sure they are made by different companies.
Reply #5November 18, 2009, 12:24:52 am
Zulfiqar
  • 254
Re: Lucas Cav Pumps
« Reply #5 on: November 18, 2009, 12:24:52 am »
im talking about the mechanical pieces - I find liqui moly better than lucas - just my experience maybe
Reply #6November 18, 2009, 01:02:33 am
Wayland
  • 364
Re: Lucas Cav Pumps
« Reply #6 on: November 18, 2009, 01:02:33 am »
Yes, Lucas's dying words were "Don't drive in the dark"
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #7November 19, 2009, 12:12:06 pm
anto
Re: Lucas Cav Pumps
« Reply #7 on: November 19, 2009, 12:12:06 pm »
Il stick to my bosch then lol
Reply #8November 19, 2009, 12:18:56 pm
Re: Lucas Cav Pumps
« Reply #8 on: November 19, 2009, 12:18:56 pm »
but ive never even heard of liqui moly. or seen it. wonder if you can get it in the US?
Reply #9November 19, 2009, 10:32:27 pm
truckinwagen
  • 1895
Re: Lucas Cav Pumps
« Reply #9 on: November 19, 2009, 10:32:27 pm »
try lubro moly,
they make great oil and fuel addatives
83 Opel Kadett Diesel
Reply #10November 20, 2009, 12:46:02 pm
Re: Lucas Cav Pumps
« Reply #10 on: November 20, 2009, 12:46:02 pm »
heard of that stuff, but i think thats another one i cant really get around here. the only additive i continuiously run is trans fluid. it gets a quart with every fill up.
Reply #11March 24, 2010, 04:46:25 pm
smutts
  • 720
    ClackClackClackClackClack
Re: Lucas Cav Pumps
« Reply #11 on: March 24, 2010, 04:46:25 pm »
Yup, another Lucas Cav Rotodiesel victim here. French Car, British Pump, and the only source of spares I can find? Germany. Does the UK make ANYTHING anymore? Sad. :P
Unfotunately a Lucas DPC service manual was sniped from it's rightful owner (ME!) :D on fleabay yesterday, so we will be in the dark for a while yet.
Reply #12March 24, 2010, 07:51:40 pm
Patrick
  • 1034
Re: Lucas Cav Pumps
« Reply #12 on: March 24, 2010, 07:51:40 pm »
Lucas might be known as the prince of darkness, but I have to say I have a LOT less trouble with lucas starters than delco.....   did the swap on my 354 perkins in my truck and won't look back.
Reply #13April 26, 2010, 07:40:41 pm
dieselherb1
  • 354
Re: Lucas Cav Pumps
« Reply #13 on: April 26, 2010, 07:40:41 pm »
I have a CAV pump on my MF180 tractor I'd like to rebuild. I was using a blend of vegoil and diesel and now I have a slime inside the pump and it won't start. I believe something is sticking(maybe shut-off valve) It was running shut off next day won't start! Took the top off the pump but don't understand the flaps and slide plate which shuts it off. I would like to have someone clean it up, but everyone wants to charge for a rebuild. I bought the seal and gasket kit($22) big jump to rebuild $500-800. I'd part it apart if I had a spare.
Reply #14April 27, 2010, 09:53:01 am
anto
Re: Lucas Cav Pumps
« Reply #14 on: April 27, 2010, 09:53:01 am »
I have a lucas cav document that might help you with your rebuild dieselherb if yuo give me your email address il forward it on....
S-PAutomotive.com
