Author Topic: how do you get the speedo gear out?  (Read 13478 times)
Reply #45April 07, 2010, 06:56:30 am
Re: how do you get the speedo gear out?
« Reply #45 on: April 07, 2010, 06:56:30 am »
steel gets stuck to aluminum. the end of my cable is steel where it goes into the trans, not plastic.
Ah I get it.  I thought that the metal part was already up, and the gear was actually stuck in there.
Yeah, I think that gasket might help prevent the dissimilar metals from sticking.  I made sure to put a new one on the Golf while it was out.
Reply #46April 07, 2010, 08:51:10 am
« Reply #46 on: April 07, 2010, 08:51:10 am »
i didnt get that lucky. my speedo cable is part of the trans as of right now. im sure i could get it out if i really wanted to, but it works, and its there, so its staying there till i need it out.
Reply #47April 12, 2010, 09:15:19 pm
« Reply #47 on: April 12, 2010, 09:15:19 pm »
I dunno what the problem is Lucas.
I popped mine out in 3 minutes to top up the lost trans oil from a leaking end cap, and popped it back in. Weird that you had to fight so much with yours ;)
Reply #48April 13, 2010, 06:12:58 am
« Reply #48 on: April 13, 2010, 06:12:58 am »
Yes it sucked. It is out. Now I definately need a new cable. I will have to see if napa or similar has one.
