Author Topic: speedo cluster removal ?  (Read 4958 times)
October 02, 2009, 03:12:59 am
bobmaf
  • 65
« on: October 02, 2009, 03:12:59 am »
can anyone give me advice on the easyest way to remove the speedo cluster from a mk2 golf as i aint got a clue
thanks bob
1991 mk2 1.6GTD tuned
1995 mk3 1.9TD Part Tuned(aaz)
Reply #1October 02, 2009, 03:26:28 am
DCC
  • 184
Re: speedo cluster removal ?
« Reply #1 on: October 02, 2009, 03:26:28 am »
1. Pull the knob and dials off the climate control gauge
2. Pull on climate control gauge
3. Remove radio
4. Remove switch blanks (pull)
5. Remove switches (push from rear of dash with figers) then disconnect from wires (pull on the plug not the wires)
6. Remove screws holding inner dash (not the cluster) in place 2 at top of gauge cluster, one on top of radio (I leave this one out so I don't have to pull my radio to pull my dash) 3 holding climate control (these are larger then all others) one behind headlight switch, one behind bottom left of the 6 switches
7. Remove the black plastic dash
8. Remove the 2 screws holding the cluster in place top right and left
9. Lift up and out on the cluster until you can see the plugs (some have 2 some have 1) on the bottom (use the flathead to unlock the plug the pull on the plug (not the wires!). The speedo cable is reachable from behind.
10. Remove cluster.  :)
Reply #2October 02, 2009, 03:39:06 am
bobmaf
  • 65
« Reply #2 on: October 02, 2009, 03:39:06 am »
thankyou for that
