Author Topic: WTB: 1.5/1.6 Diesel engine - longblock or shortblock  (Read 6220 times)
October 03, 2005, 03:31:26 am
vwmike
  • 1158
« on: October 03, 2005, 03:31:26 am »
I just bought a 79 diesel Rabbit which from what the previous owner said it sounded like they didn't clean out the bolt holes in the block when they installed a new cylinder head and it has since cracked. I don't know if I feel like rebuilding an engine so it would be cool if I could get my hands on another longblock or shortblock depending on what is available. I'll be able to tell more definitely what is wrong when I get out there and play with it tomorrow but in the mean time I figured I'd get the word out. Thanks!
Reply #1October 04, 2005, 07:55:38 pm
pete
  • 7
I've got 1984 rabbit eng. ran good needs a pump
« Reply #1 on: October 04, 2005, 07:55:38 pm »
rebuilt 150,Km ago, well rings that's 90,mi,$300.00 [email protected] Pete 519-453-7281 London
1987 2dr.Jetta 1.6L
1990 Jetta soon to be 1.6L
1992 Golf 2 dr. 1.8L $600.00
1996 GTI Parts car 2.0L
1983 Vanagon westy 1.9L
Reply #2October 14, 2005, 01:15:43 pm
vwmike
  • 1158
« Reply #2 on: October 14, 2005, 01:15:43 pm »
There has to be something closer than Ontario.
I pulled the head off and it looks like they had a 1.6 head with 12mm bolts on it. I'll have to check it for straightness, but I see no cracks between the valves so I guess I need a 1.6 short block with 12mm head bolts or a complete engine. I'd really like to find a TD, so if anyone has one around that is in good running condition I'd consider shipping that.
The block in this car is destroyed (very cracked).
Reply #3October 19, 2005, 12:30:54 pm
v8volvo
  • 71
    • http://www.cardomain.com/profile/v8volvo
« Reply #3 on: October 19, 2005, 12:30:54 pm »
I have an excellent 1.6NA short block that I *might* let go. It has 80k on it, very good condition, has brackets, pan, crank, rods, pistons, flywheel, and clutch (currently all still assembled). Ready to have a head bolted on and dropped in. I am nearby, in Seattle. Email me at [email protected] if you're interested.
Reply #4October 19, 2005, 12:49:13 pm
BlackTieTD
  • 1512
« Reply #4 on: October 19, 2005, 12:49:13 pm »
i have a 1.5L with a blown headgasket i have dillusions of someday rebuilding and using... up in ontario though. let me know if you're interested.
Reply #5October 19, 2005, 02:44:21 pm
vwmike
  • 1158
« Reply #5 on: October 19, 2005, 02:44:21 pm »
Quote from: "v8volvo"
E-mail sent  :D
Hopefully this one works out. I can't really use a 1.5 at this point since the head I have is for 12mm bolts.
Reply #6October 19, 2005, 07:15:25 pm
v8volvo
  • 71
« Reply #6 on: October 19, 2005, 07:15:25 pm »
Well...my inbox is empty...try again? I'll PM you a better email address and a phone number, just don't want those out there in public.
The motor is supposedly out of an '84 Rabbit (that ran perfectly, they took this lovely diesel out for a 16v gasser swap  :x ), so it should be what you are looking for in terms of bolt size, etc. I also have a ton of old 12mm bolts laying around so you could try one out just to be certain.
It has actually only been sitting a few months since it last ran; you could just slap a head on and maybe some fresh gaskets, or if you wanted to go full bore you could pop out the pistons, give it a quick hone, and slap some new rings in it. Everything is tight right now though, and the bores look fine last I checked.
I kinda liked the idea of having a spare short block laying around...but then again, space is a problem, and I did just rebuild the engine that is already in my car, and it sounds like you are a dieseler in need, so maybe we can work out a deal. Wish I had some pics, sorry, can't take any, but the journey to Seattle ain't that long for you.
Reply #7October 20, 2005, 05:14:40 am
Justin
  • 455
« Reply #7 on: October 20, 2005, 05:14:40 am »
you can run a 12mm head on a 11mm block all you have to do is shim the holes on the outer four bolts of the head. take a pop can and cut it up to wrap the aluminum around the outer four bolts just once, put them in and bolt it down.
later
Justin
www.archeryprostaffmi.com
Reply #8November 12, 2005, 12:28:17 am
PickupPete
  • 3
1.6 diesel
« Reply #8 on: November 12, 2005, 12:28:17 am »
I have a rebuilt 1.6 diesel engine, not started yet. $800
Also a 1991 turbo diesel engine complete (not an eco-diesel) with rebuilt head $2500
located in Oregon
Pete
541 424-3500
Reply #9November 13, 2005, 04:29:18 pm
mortskeg
  • 95
    • http://www.vwcaddy.com
« Reply #9 on: November 13, 2005, 04:29:18 pm »
email sent. :D
Reply #10November 28, 2005, 05:25:50 pm
Josh
  • 54
« Reply #10 on: November 28, 2005, 05:25:50 pm »
fyi, 1.5's are expensive to rebuild, IIRC.
'84 Quantum sedan (oops, not '83!)
'83 Quantum wagon(ditto, not '82)
'82 Westfalia
'79 Rabbit
Mmmm.  Diesely.
