Author Topic: Best swap?  (Read 3378 times)
September 28, 2009, 08:58:03 pm
brandon5
  • 88
Best swap?
« on: September 28, 2009, 08:58:03 pm »
Ok so my motor is absolute crap and im looking to swap a newer engine into it. Im still a complete noob with diesels and im learning lots everyday. I currently have a 1.6 na with a turbo and intercooler (bought like that). The car is a mk2 golf. I want to swap a motor that will leave me with lots of possibilities for power. Ive seen some stuff where people swapped in 1.9td's from mk3's and i saw one jetta with a TDI motor. Im wondering what would be the best motor for my car (mounts, room, placement). I know its going to get pricey and take a long while, but i like a challenge.
Thanks for your time and all the smart answers to a dumb question.  ::)
Brandon.
Reply #1September 28, 2009, 09:12:56 pm
rallydiesel
  • 1880
Re: Best swap?
« Reply #1 on: September 28, 2009, 09:12:56 pm »
If you go with a 1.9TD, you'll have a nice upgrade in power. Plus it's an easy drop in. Cool thing about it is if you want to go tdi, you just need to change the head and IP (and electronics if you want to go the ecu route). You'd need to go 1Z or AHU with the head and pump.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2September 29, 2009, 08:22:13 am
410
  • 581
Re: Best swap?
« Reply #2 on: September 29, 2009, 08:22:13 am »
Plus tdi pistons, injector lines and valve cover to change a 1.9 td to a tdi.  So you might as well start with a complete long block iz or ahu if you go this route.
Reply #3September 29, 2009, 08:30:52 am
brandon5
  • 88
Re: Best swap?
« Reply #3 on: September 29, 2009, 08:30:52 am »
Im looking at a 1.9 td from a 97 jetta. and a 2003 tdi from a jetta wagon.
Reply #4September 29, 2009, 09:18:52 am
rallydiesel
  • 1880
Re: Best swap?
« Reply #4 on: September 29, 2009, 09:18:52 am »
The TD will be a quick drop in and you'll be ready to go. The ALH (from the '03) requires mount modifications and an instrument cluster/complete wiring harness swap. Also, the ALH head won't fit the AAZ block. The ALH is a very good engine but putting it into a mk2 is a lot of work.
Reply #5September 29, 2009, 10:05:01 am
brandon5
  • 88
Re: Best swap?
« Reply #5 on: September 29, 2009, 10:05:01 am »
awsome thanks for the help. Ill go check the motor out if he emails me back. Ill prolly do a compression test on it and stuff to see if its good. Im also swapping in a mk3 dash at the same time.
Reply #6September 30, 2009, 07:27:05 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Re: Best swap?
« Reply #6 on: September 30, 2009, 07:27:05 am »
The AAZ is the easier swap. The next best swap is an AHU/1Z Swap from a mk3/B4 TDI.
