Author Topic: MK II cluster with tach for sale  (Read 3562 times)
September 24, 2009, 09:10:07 am
92EcoDiesel Jetta
« on: September 24, 2009, 09:10:07 am »
Here's a complete CE2 cluster from my 92 EcoDiesel that I modified by adding a tach and LCD clock from a gasser MK II CE1 cluster to replace the mechanical clock. Two magnetic triggers and instructions will be included. All you have to do is attach the 2 magnet triggers to the crankshaft pulley 180 degree apart and epoxy in place, obtain a hall effect pickup from any gasser distrubutor (you provide) and mount it to pick up the two magnet triggers and wire up the hall effect pickup to the 2 tach wires coming from the cluster and that's it. Since this was a diesel cluster, it has the yellow glow plug LED. $150 plus shipping. Any questions just ask.
« Last Edit: September 24, 2009, 09:17:12 am by 92EcoDiesel Jetta »
