Author Topic: Needed AAZ Hub ( Injection Pump ) and Rotary ( AAZ ) Vacuum Pump  (Read 3644 times)
September 22, 2009, 12:24:19 pm
SR Heer
  • 199
WTB - Needed - Wanted
I am looking to purchase the HUB off and injection pump from an AAZ that mates the three bolt injection pump (IP-TB) wheel to IP shaft for a VW 1.9 diesel engine
And also I am looking for a 1.9L diesel AAZ or 1Z or AHU ( AHU part number is 028207A ) Rotary Vacuum Pump! The rotary vacuum pump that I need has a housing that measures 1&3/4 inches diameter and gear that runs off of the intermediate shaft measuring 1&1/2 inches in diameter.
Thanks
« Last Edit: September 23, 2009, 06:35:19 pm by SR Heer »
97 Passat 1Z, 98 Jetta AHU, 91 Jetta AAZ TD, and 81 Rabbit Pickup
Reply #1September 30, 2009, 02:18:13 pm
GEE-BEE
  • 1604
Re: Needed AAZ Hub ( Injection Pump ) and Rotary ( AAZ ) Vacuum Pump
« Reply #1 on: September 30, 2009, 02:18:13 pm »
zsi786 Ebay  seller I.D. has new vac pumps in stock for the AAZ 199.00 , 10 in stock
Gee-Bee
I purchased a nos fuel gauge and a black with red trim dash from them
Next a new 90 amp Alt for a spare , ebay 119.95
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
