Author Topic: How do you attach the clutch cable to the clutch pedal???  (Read 5421 times)
September 21, 2009, 07:28:01 pm
mtnbob
  • 738
« on: September 21, 2009, 07:28:01 pm »
Is there a trick to it, or are my hands just too damn big??? I have tried everyway to connect them, but it is hard to see what i'm doing. Not sure where exactly the cable connects. The Bentley book is not that definitive in that area. Any suggestions?
« Last Edit: September 23, 2009, 07:01:24 pm by mtnbob »
96 Subaru Outback Wagon
Reply #1September 22, 2009, 04:53:39 am
Re: How do you put the clutch cable on the clutch???
« Reply #1 on: September 22, 2009, 04:53:39 am »
What end are you working on?
Reply #2September 22, 2009, 03:21:03 pm
mtnbob
  • 738
« Reply #2 on: September 22, 2009, 03:21:03 pm »
Just trying to get the stupid thing attached to the clutch pedal. I'm a big guy and it is hard for me to get up in there, plus it is hard to see. I'm upside down wearing a headlamp, trying to put this thing on, but having no luck ::) Any tips to make it easier? Not sure exactly how it attaches. When I took the old one off, it was mostly by feel. 8)
Reply #3September 23, 2009, 03:58:45 pm
mtnbob
  • 738
« Reply #3 on: September 23, 2009, 03:58:45 pm »
Still looking for suggestion on this one. 8)
Reply #4September 23, 2009, 08:55:15 pm
Re: How do you attach the clutch cable to the clutch pedal???
« Reply #4 on: September 23, 2009, 08:55:15 pm »
Lay all the seats down, open the hatch, tie a rope around your feet and crawl in through the hatch head first, the other end of the rope is tied around a tree. Your head will lay on the floormat. After you get it hooked up your back and legs won't function properly and your ribs will ache. To get out put the car in first gear, reach up and turn the key......hopefully the car won't hit anything. hehe ;D
I know it's a pain but I usually loosen the cable using the adjustment at the tranny and lay on the floor rail (whatever it's called) on my back with a light in there already, once you see it it's pretty simple. It's just a hook on the pedal and a plastic cable end that just slips over the hook. Good luck. :)
