Author Topic: New intake Tube elbow gasket 1.9 AAZ  (Read 2130 times)
September 18, 2009, 06:25:51 pm
GEE-BEE
  • 1604
« on: September 18, 2009, 06:25:51 pm »
Iam going to make a die for the intake elbow..
Iam will be using .032 silicone with a fiberglass insert, It's the same materail I use for the KTM motorcycle valve cover gaskets..
I keep .032, .062 and .093 in stock in various colors for different customer needs..
I mfg silicone gaskets ( baffle seals ) for 465 different model of aircraft, all die-cut with a clicker press
I just finished making the tool for the caddy rear bump stop's today, 250 pairs in production
If any one would want's one let me know and I will get one in the mail to you..
Ijust finished drill my exhaust and intake manifold's before the get ceramic coated and the intake poweder coated along with the heat sheild's..
Polishing out the S/S Techtonic's 2'5 downpipe and sending the complete exhaust out for ceramic coating at the same time..
I removed everything from the engine compartment for ( bracket's  etc ) for satin black powder coating most not structural screws are S/S now.
I found a new brake booster and master cylinder for the MKII pedal swap since I"am doing G60 brakes on my caddy
Not much left except a empty bank account fund  :'(
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1September 18, 2009, 06:52:29 pm
macka
  • 957
Re: New intake Tube elbow gasket 1.9 AAZ
« Reply #1 on: September 18, 2009, 06:52:29 pm »
On a non dub related note, do you make all makes of Lycoming gaskets???
Quote from: Vincent Walden
Reply #2September 18, 2009, 10:18:04 pm
GEE-BEE
  • 1604
GASKETS
« Reply #2 on: September 18, 2009, 10:18:04 pm »
Yeas and I also make intake duct's and silicone hose
Aircraftspruce.com
is my stock dealer..
Giles Pump OHC
MK1 JETTA DASH
Reply #3September 19, 2009, 09:44:20 am
87octane
« Reply #3 on: September 19, 2009, 09:44:20 am »
I need a pic of the stocker assy to see the angles and sizes and all but I'm probably very interested in one or more.
Reply #4September 20, 2009, 07:41:46 am
GEE-BEE
  • 1604
« Reply #4 on: September 20, 2009, 07:41:46 am »
Give me your address , I will mail you a couple of freebie's
gee-bee
Giles Pump OHC
MK1 JETTA DASH
