Author Topic: tell me about block heater kits (searched)  (Read 6418 times)
September 18, 2009, 11:02:37 am
ashleyroe
« on: September 18, 2009, 11:02:37 am »
i have a block heater kit.
i know the basics on how to hook it up. ie the freeze plugs and what not,
but please, tell me everything you guys know.
Reply #1September 20, 2009, 08:53:09 am
ashleyroe
Re: tell me about block heater kits (searched)
« Reply #1 on: September 20, 2009, 08:53:09 am »
or not!
Reply #2September 20, 2009, 10:38:17 am
GIDDY_UP_GO
  • 114
« Reply #2 on: September 20, 2009, 10:38:17 am »
Where did you get your block heater kit and how much was it? I would like to put one on my lil Golf. I think that is one mod that I can do myself!  ;)
86 MK2 Golf Diesel
Reply #3September 20, 2009, 11:23:52 am
Baron VonZeppelin
« Reply #3 on: September 20, 2009, 11:23:52 am »
Unless its arctic outside, you only need to run them for about an hour or two before cranking. Most folks use a timer that is properly rated/grounded.
Your cabin heater will be warm right at start up which would be nice too.
Incorporate something large and/or highly visible to the drop cord - some kind of something that will remind you to unplug it before taking off out the driveway.
That's the biggest issue i've heard about them - is forgetting to unplug before getting in and going.
Reply #4September 20, 2009, 01:32:49 pm
« Reply #4 on: September 20, 2009, 01:32:49 pm »
One other hint... secure the power cord carefully so that it doesn't drop down against the exhaust manifold.
Reply #5September 21, 2009, 07:02:57 am
« Reply #5 on: September 21, 2009, 07:02:57 am »
I've got this one:
http://www.germanautoparts.com/Volkswagen/Golf/EngineElectrical/396/1
In the wife's car.
Not on the road yet so I don't know how well it works.  :)  I have the plug connected now, I'll probably loom the wires together with the EGT wires in a heat-sleeve type deal.  I'll have more pictures later, I'm behind in that department, at this point I just want the build finished.  :P
Reply #6September 21, 2009, 10:26:07 am
macka
  • 957
« Reply #6 on: September 21, 2009, 10:26:07 am »
don't forget to unplug it before driving away. I see lots of people up here with extension cords dragging down the road after the first big freeze up.
Quote from: Vincent Walden
Reply #7September 21, 2009, 06:28:43 pm
ashleyroe
« Reply #7 on: September 21, 2009, 06:28:43 pm »
the previous own had bought it from the dealer ship but never hooked it up.
it was in the trunk with the rest of the extras.
it has no instructions or anything with it.
so i'm alittle lost on proper hook up, care and everything else.
Reply #8September 22, 2009, 02:58:44 pm
« Reply #8 on: September 22, 2009, 02:58:44 pm »
If it is a freeze plug style look above at Lord V's pic...you basically knock the freeze plug out with a screwdriver or punch or tek screw and pull with a hammer. Then screw the heater in its place. Mine said to put it in the freeze plug closest to the timing belt side of the engine, but I am sure there are different types. I got mine at napa auto parts. If you could tell what brand yours is then go to a distributor of them I am sure they would let you know what the proper procedure is. Or just wing it :D
