Author Topic: Best way to Remove Valve cover Studs  (Read 4612 times)
September 15, 2009, 03:53:09 pm
Peter
  • 136
« on: September 15, 2009, 03:53:09 pm »
..I was able to remove only 2 studs and the rest of them are very tight ...my Fear is that I might snap them off.. hard to determine the amount of pressure to be applied when useing a large vise grip...any ideas??...no luck with "double" nuts either
« Last Edit: September 15, 2009, 03:54:45 pm by Peter »
Reply #1September 15, 2009, 04:03:37 pm
Re: Best way to Remove Valve cover Studs
« Reply #1 on: September 15, 2009, 04:03:37 pm »
Try harder? I would be surprised if they snapped. You might try hitting them squarely on the top with a hammer lightly several times. I say lightly because if you go to hard it may be possible to crack the head.
I was going to say vise grips or double nut but you have those bases covered. I'm presuming you are switching to studs for the rubber valve cover?
Reply #2September 15, 2009, 04:45:12 pm
Peter
  • 136
« Reply #2 on: September 15, 2009, 04:45:12 pm »
..yes, the rubber valve gasket and try harder I will
Reply #3September 15, 2009, 10:06:21 pm
  • 2932
« Reply #3 on: September 15, 2009, 10:06:21 pm »
There is a special stud remover tool.
 I don't have one,.. vice grips or double-nut for me.
 I blue locktite the new studs in so I don't have to deal with them coming out with the nuts, next time I remove the cover.
Reply #4September 16, 2009, 06:39:25 pm
Peter
  • 136
« Reply #4 on: September 16, 2009, 06:39:25 pm »
Trying harder with no fear of breaking the studs worked out OK...drip-free now with the installed rubber gasket
Reply #5September 17, 2009, 08:40:43 pm
  • 2932
« Reply #5 on: September 17, 2009, 08:40:43 pm »
Great.
 I've been using the rubber valve cover gaskets for years.
 I bought a bag of long set screws so I can put the studs in with an allen wrench.
 I installed my first rubber oil pan gasket today,.. now that I know the part number; I don't intend to use another fiber gasket.
Reply #6September 18, 2009, 05:32:30 pm
Rabbit TD
  • 840
« Reply #6 on: September 18, 2009, 05:32:30 pm »
I want to get one of those too.  Lots of times we'd like to have the valve cover off for one reason or another but hate to break a good seal that is so damn hard to get it seems like and end up tearing the gasket up anyhow in the process.
