Author Topic: Is there an easy way to remove the 1.6 N/A airbox?  (Read 4291 times)
September 12, 2009, 01:08:32 pm
mtnbob
  • 738
« on: September 12, 2009, 01:08:32 pm »
Or do I have to get the intake manifold of first? ::)
96 Subaru Outback Wagon
Reply #1September 12, 2009, 01:09:55 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
Re: Is there an easy way to remove the 1.6 N/A airbox?
« Reply #1 on: September 12, 2009, 01:09:55 pm »
Dosent half of it just snap off?
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #2September 12, 2009, 01:23:48 pm
  • 1739
« Reply #2 on: September 12, 2009, 01:23:48 pm »
there are 4 or 6 bolts underneath that hold the metal and plastic parts together. I believe it's possible to do in place, however you may need a long extendtion to reach them
Reply #3September 12, 2009, 02:20:45 pm
mtnbob
  • 738
« Reply #3 on: September 12, 2009, 02:20:45 pm »
OK ty
Reply #4September 12, 2009, 05:57:37 pm
Rabbit TD
  • 840
« Reply #4 on: September 12, 2009, 05:57:37 pm »
I've never seen anything other than the 4 snap spring things that hold the cover on, at least the ones down here in the states anyways.
Reply #5September 12, 2009, 08:01:02 pm
mtnbob
  • 738
« Reply #5 on: September 12, 2009, 08:01:02 pm »
Yes, i realize the top comes off with clips, i'm talking about the bottom half ::)
Reply #6September 12, 2009, 08:46:10 pm
Rabbit TD
  • 840
« Reply #6 on: September 12, 2009, 08:46:10 pm »
Then yes you will have to remove the intake manifold, that is what the whole aluminum part is called.  It's all one peice after the air filter box is off held on by 6 - 6m/m allen heads on the back between the exhaust manifold bolts and one hanger brace right in the middle on the outside.  Probably easier using some 1/4 in stuff back there, they're not hard to get out but they are nerve racking to get the bit in and make sure it's fully seated so you don't round it out.  Don't put it back on without that little brace thing either, the whole damn thing can come loose without it.  I had that hapen on my N/A some years back.  I kept hearing this tinking sound every couple minuets on the way home, {the bolts were falling out 1 at a time}, then at a red light I noticed the engine sounded a lot louder but ran fine.  When I got home the intake was clear off the head  about a half inch or so away.  Can you tell me another car that will run without the intake manifold on it?
Reply #7September 12, 2009, 11:58:49 pm
mystery3
  • 774
« Reply #7 on: September 12, 2009, 11:58:49 pm »
On the mkII's the intake manifold is like half aluminum and half plastic. It looks like the plastic part would come off separately but I'm only speaking from looking at them in the junkyard.
