Author Topic: aaz in mk2 golf???  (Read 1965 times)
September 09, 2009, 11:19:56 am
citigolf
  • 12
aaz in mk2 golf???
« on: September 09, 2009, 11:19:56 am »
is it possible to dropp an aaz straght in and run my 1.6td manifolds and turbo???
i realise i will need to change all the mounts.....
but is there anything else?  will everything wire up the same? pump? ect?
cheers
Reply #1September 09, 2009, 01:03:49 pm
boomenstein
  • 35
Re: aaz in mk2 golf???
« Reply #1 on: September 09, 2009, 01:03:49 pm »
I just did this swap this weekend.
See
http://www.vwdiesel.net/forum/index.php?topic=21122.0
Mine was a 1.6NA
The downpipe from the MK3 fits if you have that.
The only mount you will need to change is the rear passenger, the MK2 uses 3 bolts and the MK3 uses 1.
Just swap that mount off you 1.6 and your golden.
