Author Topic: Needed, lower timing belt cover for 1984 1.6L  (Read 4025 times)
September 09, 2009, 07:47:07 am
arb
« on: September 09, 2009, 07:47:07 am »
I had a belt try and walk off the pulley's and it cut the plastic cover nearly in half. Fixed the tracking problem but would like a fresh cover. If you have one, please let me know.
Reply #1September 09, 2009, 10:18:42 am
arb
Re: Needed, lower timing belt cover for 1984 1.6L
« Reply #1 on: September 09, 2009, 10:18:42 am »
While I'm at it, it would be nice to get the baffle put over the cam after 1984....
Reply #2September 09, 2009, 09:12:11 pm
Quantum TD
  • 1195
« Reply #2 on: September 09, 2009, 09:12:11 pm »
Parts Place Inc in Michigan should sell the lower cover new for like $30-50, or try your local dealer. At least it won't be warped/worn thru/cracked.
Reply #3September 10, 2009, 01:21:13 am
  • 2932
« Reply #3 on: September 10, 2009, 01:21:13 am »
With belts running around on the inside and out.
 It's hard to find one in great shape.
 Believe it or not,..
 go to the dealership with the part number off the old cover.
  That's the cheapest place I've found them $38.78. and no shipping.
 You might be able to find a good used one for less.
« Last Edit: September 10, 2009, 01:24:13 am by fatmobile »
