1Z crankshaft question
Topic: 1Z crankshaft question (Read 3328 times)
September 08, 2009, 08:21:38 pm
jack's lack
September 08, 2009, 08:21:38 pm »
What is this disk on the 1Z crank that is not on the AAZ crank? and can I remove it?
I posted this in my build thread, but the general section gets almost no traffic, so I figured I would ask over here
Thanks
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
September 08, 2009, 08:26:13 pm
rallydiesel
Re: 1Z crankshaft question
September 08, 2009, 08:26:13 pm »
Are you sure that's not a gasser crank? Maybe my eyes are tricking me, but the flywheel bolt holes don't look staggered like they should be on a diesel crankshaft.
1991 Jetta TD - sold
2001 Golf TDI - Son's
September 08, 2009, 08:41:23 pm
jack's lack
September 08, 2009, 08:41:23 pm »
oh, the flywheel bolts up just fine, probably just the photo. I bought it from a guy in Canada on the vortex. He was parting out a TDI and he said it was a 1Z. I took him on his word.
Apart from the D-shaped keyway and the piece in question they appear to be identical. I failed to mention that this is going in my AAZ to preclude the whole keyway disaster scenario. I thought that was a given, but hindsight makes me think I should have mentioned it in my original post
My Build Thread
September 08, 2009, 09:33:10 pm
starrd
September 08, 2009, 09:33:10 pm »
On the 1Z TDI, there is a crank sensor that is machined into the block which uses that sensor plate. It can be removed if you like, but it doesn't do any harm. The sensor is used for an input to the electronic injection system on the TDI.
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
September 08, 2009, 10:45:14 pm
jack's lack
September 08, 2009, 10:45:14 pm »
Thanks, I just found it in the Bentley. I guess I should have looked a little harder first. It adds weight to a rotating part, granted it isn't much, but since the IDI doesn't need it I think I will remove it.
My Build Thread
September 09, 2009, 09:43:07 am
September 09, 2009, 09:43:07 am »
yea, thats just a reluctor ring. you dont need it if you are going to be running IDI.
