Author Topic: TDI parts UK  (Read 3447 times)
September 08, 2009, 11:08:04 am
Andrewb
TDI parts UK
« on: September 08, 2009, 11:08:04 am »
These bits came off a 2001 Caddy with an AHU TDI (probably one of the last AHUs??)
Inlet manifold and EGR pipe. £20
Drive shafts. £30
Gear lever mechanism and cables. £20
I'm also selling all the wiring; I did attempt to get this working on my project, but ended up running into immobiliser problems and went the MTDI route. Included is ECU, instrument cluster, accelerator sensor, immobiliser, fuse and relay block, ignition barrel (I think the steering lock is jammed, but you can put the key in for the sensor and operate the switch removed from the back with a screwdriver, obviously a different solution would be needed when finishing off your project).  £50
Half the gearbox! I used part of the casing as a bellhousing. Free - collection only
Also have a VW electric fan from a petrol Golf £5
I'm able to post most parts at buyers expense and am open to reasonable offers.
Thanks for looking
Andrew  :)
« Last Edit: September 08, 2009, 11:11:39 am by Andrewb »
Reply #1September 14, 2009, 07:23:01 pm
catlin_cava
  • 1954
Re: TDI parts UK
« Reply #1 on: September 14, 2009, 07:23:01 pm »
How much do you want for the Fuse Panel?
Catlin
2010 VW Golf City 2.0L "Hers"
