Author Topic: Taller 5th gear, where to get one  (Read 18082 times)
Reply #30September 13, 2009, 05:59:11 pm
Re: Taller 5th gear, where to get one
« Reply #30 on: September 13, 2009, 05:59:11 pm »
the thing with short gear transmissions and our cars is that our engines red line at a low speed so the benefits of the short ratios aren't as productive with our cars, especially when you have a turbo
Reply #31September 19, 2009, 08:38:55 pm
Doakster
  • 291
« Reply #31 on: September 19, 2009, 08:38:55 pm »
Trans is back together with all new seals, a peloquin and 3.94 final. Also painted it machine gray. Going to try and get it back in the car tomorrow. Thanks for all the input fellas.
And thanks to Scott for sending me to George, what a stand up guy. I watched him reassemble the trans and learned a thing or two.
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #32September 20, 2009, 08:01:52 pm
tSoG-84bit
  • 188
« Reply #32 on: September 20, 2009, 08:01:52 pm »
crap, I've got a 4S sitting in my barn that I'd have gladly traded for a AVX...  :'(
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #33September 20, 2009, 10:57:54 pm
janb
  • 167
« Reply #33 on: September 20, 2009, 10:57:54 pm »
agreed, the AVX is 'gold' to auto-x.  Usually they will trade 2 good gas trannies for each AVX,
I use .71's out of older "A1" trannies, and really like a 9A w/ .71 for GTD driving, but I use ACN / AGS (Gas stock) for 'flatlander' 1.6 NA's or TD's in the mtn.
I would change the Eco Turbo to a 'larger' 1.6 turbo + an IP with Boost.  Should be able to find a package deal for under $500.
The Stealth Rabbit
VW-d's are forever
Reply #34September 21, 2009, 03:21:36 pm
Doakster
  • 291
« Reply #34 on: September 21, 2009, 03:21:36 pm »
Any idea what you guys think i can get for the 4.25 R&P that came out of my AVX
Reply #35September 22, 2009, 06:22:18 pm
larry104
  • 200
« Reply #35 on: September 22, 2009, 06:22:18 pm »
I have a 1992 EcoDiesel; Giles LDA pump, 2-1/4 in. exhaust, GTD intercooler and injectors, boost controller, stock K14 turbo. I sold the 4.25 R&P, found a .71 top gear and a 3.67 R&P and had http://www.aatransaxle.com/ rebuild it (the trans has worked flawlessly since rebuild 20,000 miles ago). The car was an absolute dog before the mods. It could barely hold 65 mph on even shallow grades. It now runs incredibly and easily pulls the taller gears. It'll smoke a Honda Civic ;D in stop and go traffic and run comfortably all day long at 75 mph on the interstate. And, the best part: I get better mileage than before the mods. City, if I drive sensibly, returns 44-46 mpg. Highway with cruise control (Audivox setup -- love it) set at 65 mph delivers 48-50 mpg. Taller gears as part of other performance upgrades makes good sense. Stock, an Eco would have a tough time pulling taller gears, imo.
Reply #36September 22, 2009, 06:51:50 pm
Doakster
  • 291
« Reply #36 on: September 22, 2009, 06:51:50 pm »
That's some great feedback. Only thing i did at the same time as the trans mods was a 2 1/4in exhaust. I doubt that will give me much for now but hopefully a MPG or two. Maybe a giles LDA pump in the spring.
Reply #37September 22, 2009, 07:42:25 pm
larry104
  • 200
« Reply #37 on: September 22, 2009, 07:42:25 pm »
It's money well spent. Giles knows injection pumps. I also had him do the VE pump on my 12V Cummins powered '91.5 Dodge pickup. HUGE performance gain.
Reply #38September 22, 2009, 09:36:18 pm
ozzie
  • 25
« Reply #38 on: September 22, 2009, 09:36:18 pm »
Your conversation is over my head - I am not getting the gear ratios v. final drive, etc...
I am interested in MPG (not preformance) in my 85 TD Jetta.  I have had the car for 14 years and recently lost 5th gear.  The trans case is in poor condition so I need to purchase a used trans.  I drive a ton at 70 mph.  Should I be looking for the AVX for the best mileage?  I am on a budget and want to avoid custom gearing.
Reply #39September 23, 2009, 07:34:59 am
« Reply #39 on: September 23, 2009, 07:34:59 am »
an AVX is garbage for mileage. sell it to some racer on the whortex. it has 4.25:1 final drive. you will not get real real good mileage with an AVX. now if you put something with a .71 fifth gear and something besides 4.25's, it would work better. that is the lowest geared trans you could ever get in a stock VW. my AUG has 3.67 final drive gears and does fine on the highway.
Reply #40September 24, 2009, 11:13:55 am
ozzie
  • 25
« Reply #40 on: September 24, 2009, 11:13:55 am »
Thanks Kevin.  Good info.  I have an extra gasser trans and after searching the forum it looks like that might be an option to stick in there.  I will check the code see what the ratios look like.  lower rpm's will be good for the 'montana super 2 lane' highway driving  (70 - 75 mph).  thanks
Reply #41September 25, 2009, 08:22:56 am
« Reply #41 on: September 25, 2009, 08:22:56 am »
if you want a really sweet trans, just swap in some 3.94 or some 3.67 final drive gears in there. its already layed out right gear wise, just needs taller final drive.
Reply #42September 25, 2009, 05:13:34 pm
Doakster
  • 291
« Reply #42 on: September 25, 2009, 05:13:34 pm »
And that's exactly what these guys convinced me to do.
Reply #43September 25, 2009, 07:45:23 pm
ozzie
  • 25
« Reply #43 on: September 25, 2009, 07:45:23 pm »
The gas jetta I bought for the sheet metal (I hit yet another deer) has an ASF 5 sp trans.  That might work well for highway cruising.  The car was not drivable when I got it so I will have to look it over closely before I think about putting it in.
Doakster - are you happy with how things turned out with your trans?  And did you find somebody that wanted the AVX?  Swaping out the final drive might not be something I can do - I will read up on it this weekend.
Oz
Reply #44September 26, 2009, 01:45:06 pm
Doakster
  • 291
« Reply #44 on: September 26, 2009, 01:45:06 pm »
Oz
I actually haven't fired/drove it yet since the trans went back in. I was doing a bunch more parts at the same time for other stuff on the car and forgot a few things, hopefully it will be up and going by the end of next week.
I actually didn't take out the AVX, just swapped the ring and pinion out for a 3.94 ring and pinion, and put it back into. The R&P swap requires a complete tear down of the trans. When i pulled the trans to do my clutch it had a bunch of oil leaks on it, so i decided to put some different gears in there and a peloquin limited slip while it was apart.
