Author Topic: Forged TDI rods + AAZ block = FAIL  (Read 11231 times)
Reply #15September 09, 2009, 03:18:21 pm
MRTANGOMAN
  • 51
Re: Forged TDI rods + AAZ block = FAIL
« Reply #15 on: September 09, 2009, 03:18:21 pm »
I brought some of these for my 1.6 gtd i'm building.
from these guys on e-bay .
http://myworld.ebay.co.uk/maxspeedingrods
been delivered today .. they look the biz
Reply #16September 09, 2009, 05:24:00 pm
Syncroincity
  • 727
« Reply #16 on: September 09, 2009, 05:24:00 pm »
These are the Intengineering rods. Basically the same design.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #17September 09, 2009, 05:40:23 pm
rallydiesel
  • 1880
« Reply #17 on: September 09, 2009, 05:40:23 pm »
Are these the ones they list for the rabbit? How's the fitment? Are they identical dimensions to the GTD rods?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #18September 09, 2009, 10:43:19 pm
Syncroincity
  • 727
« Reply #18 on: September 09, 2009, 10:43:19 pm »
Alien Autopsy Photos!
The rods & pistons:
Before:
After:
Tight quarters, but it doesn't come closer than this, perigee at about 2mm away from the squirter mount tab. (As seen from the intermediate shaft...bad photo angle; it looks closer than it really is.)
JC McCavitt
'98 Jetta Wolfie
Reply #19December 03, 2010, 10:41:36 pm
myke_w
  • 1099
« Reply #19 on: December 03, 2010, 10:41:36 pm »
I know this is late - but.
The OTHER difference is that the intermediate shaft gear will have to be massaged because #4 rod will possibly smack the driver side edge of it. rotate the assembly with the shaft in to check.
This is what they used to have to do in the 1.8 8v and 2.0 aba to put monster rods in them back in the day.
Sadly, integrated engineering had not test fitted on ahu /1z so customers like you got caught up in that mess. What thier site shoulkd say if it does not already is "Direct fit for ALH TDI ONLY" m* may fit earlier models with modifications.
That's high performance parts though, always a trade off.
Reply #20December 04, 2010, 07:26:06 am
« Reply #20 on: December 04, 2010, 07:26:06 am »
The first version of IE's forged ALH rods needed block clearancing even in ALH engines, so it may be that you got an early version and the block internals are the same.
Or: I built up my most recent ALH with IE's newest design and they fit perfectly but just...all that extra beefiness has gotta go somewhere.  So if there are even subtle differences in the blocks that doesnt show when using stock rods I can see how using bigger rods would make it apparent.
Having said all that, they are beautiful rods, aren't they?!
« Last Edit: December 04, 2010, 07:31:11 am by Vincent Waldon »
Reply #21December 04, 2010, 08:19:44 am
Syncroincity
  • 727
« Reply #21 on: December 04, 2010, 08:19:44 am »
That's right, I put everything back together and it STILL didn't want to turn all the way around, I finally figured out that it was hanging up on the intermediate shaft. I couldn't actually see what was going on until I popped out the shaft galley freeze plug at the flywheel end of the block.
It appears to hit the drive gear.
I did some shaving on the shoulder of the rod to get it to clear... there goes my matching balance, but oh well, at that point I didn't care any more. Hopefully a few grams won't be noticeable on a low-rev motor.
Thanks for bringing this up, I forgot to add any updates after that issue.
JC McCavitt
'98 Jetta Wolfie
Reply #22December 06, 2010, 07:59:20 am
dirtydiesel
  • 35
« Reply #22 on: December 06, 2010, 07:59:20 am »
they will fit just do lots of grinding. i just did the same thing last week with my AAZ.
